"Free Air" Sub
Old Jul 20, 2009 | 05:46 PM
  #41
Grand_hustle17's Avatar
what do u guys think of this??? $75... then again im sure i could get suttn at work
Orion CO235 2 channel amp
Old Jul 20, 2009 | 05:47 PM
  #42
Originally Posted by DAVE Sz
I don't think those will be necessary...
because???
Old Jul 20, 2009 | 08:19 PM
  #43
Jreed2008's Avatar
because???
I think he was been sarcastic because you said something about pictures of wood ..............Anyway goodluck on the install it should fit fairly easy in stock location just deaden and sealing portions of the trunk could help.
Old Jul 20, 2009 | 08:28 PM
  #44
lol... o.k
Old Jul 21, 2009 | 05:32 AM
  #45
Mr. Wet's Avatar
Good luck with that dude. Can't wait to see the pics.
Old Jul 21, 2009 | 08:00 PM
  #46
lil update...
kinda got started late with the pic
my buddy who was doing most the work
Old Jul 21, 2009 | 08:01 PM
  #47
now im still debating on an amp
Old Jul 21, 2009 | 08:36 PM
  #48
MoncefA33's Avatar
What's the RMS rating?
PM me, I can get ahold of one for ya.
Old Jul 22, 2009 | 06:00 AM
  #49
just suttn small... 100-150 rms
Old Jul 22, 2009 | 06:20 AM
  #50
MysticCBR's Avatar
is the grill going to be able to fit back over that ?
Old Jul 22, 2009 | 06:26 AM
  #51
no, if u look i had to cut a lil bit cause the board was too thick... but what im planning on doing is get a peice of cardboard (or whatever that material is called that is over the spare tire in the trunk) carpets it the same color and cut out the area for the sub and spray glue it on the surround of the rear deck, so it looks like one flat peice and just the sub comng out of the carpet
Old Jul 22, 2009 | 06:57 AM
  #52
vball_max's Avatar
What thickness board is that? It looks really thick..... if you used a 1/2" or 5/8" mdf, do you think the stock cover would fit over it?
Old Jul 22, 2009 | 06:59 AM
  #53
nismos14's Avatar
§è~® f®ÈÄk
bottom mount the sub.
Old Jul 22, 2009 | 07:11 AM
  #54
maybe... im not sure... its 3/4" board
Old Jul 22, 2009 | 07:12 AM
  #55
lopezi's Avatar
Just curious if anyone has tried using any of the Tang Band 6x9 Subs mounted in the same location, either free-air or using a pre-built 6x9 box?
Old Jul 22, 2009 | 07:14 AM
  #56
i was gonna do that, but i already cut the carpet up top... if it fails ill just do the bottom mount... the width of the lip of the sub is whats the problem... im not even sure it would fit the opening
Old Jul 22, 2009 | 07:20 AM
  #57
nismos14's Avatar
§è~® f®ÈÄk
Cut the opening a bit.
Old Jul 22, 2009 | 07:26 AM
  #58
its metal
Old Jul 22, 2009 | 07:32 AM
  #59
nismos14's Avatar
§è~® f®ÈÄk
Yea and?
Cutting metal isn't that bd.
Old Jul 22, 2009 | 07:46 AM
  #60
Old Jul 22, 2009 | 07:49 AM
  #61
nismos14's Avatar
§è~® f®ÈÄk
Old Jul 22, 2009 | 07:52 AM
  #62
nismos14's Avatar
§è~® f®ÈÄk
Old Jul 22, 2009 | 08:11 AM
  #63
perkman87's Avatar
very nice ^^
Old Jul 22, 2009 | 08:12 AM
  #64
perkman87's Avatar
do u have it installed where the bose sub was???
Nope, Just In a Mdf box. Original Sub still there.
Old Jul 22, 2009 | 08:17 AM
  #65
that is well
Old Jul 22, 2009 | 05:16 PM
  #66
Jreed2008's Avatar
Yea and?
Nismo where is the best place to get a pair of these?? There exactly what I need and 2 think I was ready to pull out the Sawzall for nothing
Old Jul 22, 2009 | 05:49 PM
  #67
probebly a lowes or home depot, i want one too
Old Jul 22, 2009 | 06:00 PM
  #68
nismos14's Avatar
§è~® f®ÈÄk
Yup, loewes, HD, sears hardware etc.
Old Jul 23, 2009 | 10:38 AM
  #69
Emaximus's Avatar
Nice looking install. I didn't know you were doing 2 subs back there.
Old Jul 23, 2009 | 07:10 PM
  #70
that is a beaut
Old Jul 25, 2009 | 12:51 PM
  #71
MysticCBR's Avatar
i would bottom mount it or use a thinner pieace of wood ...i think that wood is a little overkill
Old Jul 25, 2009 | 04:11 PM
  #72
lls or just carpet
Old Jul 26, 2009 | 08:51 PM
  #73
Emaximus's Avatar
You get everything finished, how about that amp?
Old Jul 27, 2009 | 01:41 PM
  #74
just bought the carpet today... still procrastinating on the amp... however i did find the amp im going to buy... just kinda focused on my coilover/suspension right this second
Old Aug 2, 2009 | 05:05 PM
  #75
just for an update... The KICKER C8 sub is not a free air sub... pure false advertisment, just finished the setup and it was as if i did nothing, the sub never even moved
Old Aug 2, 2009 | 05:23 PM
  #76
nismos14's Avatar
§è~® f®ÈÄk
It's a free-air sub, you just don't have enough power for it.
Old Aug 2, 2009 | 05:27 PM
  #77
i used the Apline MRP-M350 amp
Old Aug 2, 2009 | 05:45 PM
  #78
nismos14's Avatar
§è~® f®ÈÄk
If the sub didn't move, somethings not right. How did you get signal to the amp? Did you adjust hte gain?
Old Aug 2, 2009 | 05:56 PM
  #79
yes... the amp got signal... the sub moved but extremely minimal, even with gain tuned all the way up, the sub probebly moved 2mm up and down
Old Aug 2, 2009 | 06:14 PM
  #80
is there anything i can do to check if the sub is working properly???
