Speakers 4th gen
Old Aug 27, 2009 | 04:21 AM
ampire's Avatar
Speakers 4th gen
Just finished installing my front door speakers (sorry didn't take pictures). What a big nuisance it was. I put in a set of Peerless midbass woofers. I had to cut a mdf shape with a 6.5" hole in it, tnut it, drill out/countersink holes, then bolt that bastard where that stupid black plastic frame is. Now amazingly the mdf bolted on well but the tnuts didnt quite line up so I was only able to screw in 3 of the 4 screws holding the peerless in. . I used a frost king foam weatherstripping to seal it and its fairly tight now I guess. How do you guys handle these installs? MDF ring? Right now I have to add a set of tweeters and take the rear deck out to put 2 more Peerless woofers. I was probably going to use pyramid car tweeters with the supplied crossover because my local indy electronics store doesnt stock anything else and I only have a few more days to go before I am back at college with no time to waste (so I can't wait for partsexpess). My question is, how hard are the rear speakers to get out? Is the mounting frame as proprietary on the rear deck as the door ones? I am sick of cutting MDF. The door speaker was sort of a 20 hour+ project. Cut MDF, fit to door, doesn't fit, chuck, repeat.
Old Aug 27, 2009 | 06:48 AM
Coolsaber57's Avatar
The speakers aren't that hard to get out.
1. Remove rear bench
2. Unbolt rear backrest
3. Pop off pillars
4. Remove rear deck
5. ???
7. Profit.
Old Aug 27, 2009 | 07:46 AM
ampire's Avatar
yep got them out in about a half hour. Rewired them to my head unit with 16 guage instead of factory wiring harness. Decided to leave them stock instead of peerless because I have 4 peerless woofers, might as well have a back up in case the fronts blow and same for the panasonic whizzers that come with it. Gonna go get the cheapo pyramid/pyleocrap tweeters and get whatever has the lowest frequency range. The midbasses I have in the front seem to only go to about 70hz to 2000hz.
Old Sep 24, 2009 | 10:04 AM
mantle7yanks3's Avatar
i want one
MAXSE5SPD
Sep 17, 2022 04:00 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
220k+ A32
Sep 11, 2015 02:18 AM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
