Pioneer-DEH-P4100UB
Old Sep 30, 2009 | 09:55 AM
icemanf14d's Avatar
Sunlit Sand Beauty
Pioneer-DEH-P4100UB
http://www.crutchfield.com/p_130P410...B.html?tp=5684
i was thinking of getting this unit...
problem is...i dont know much about audio...
1. will the original bose speakers sound good with this unit?
2. will the original bose amp/speakers work/sound good with it?
at this time my bose sub/amp are as mute as they can be paired with the original HU...which also happened to stopped playing CDs which is why Id like to replace it...
Thanks ya'll!
Old Sep 30, 2009 | 10:13 AM
w8lifter21's Avatar
Any aftermarket radio will improve the sound of OEM speakers. Advise would be to either use, or have who ever is doing the install, to use something similar to the Metra 70-7551 harness. It uses a low level output to go to the amps to be amplfied. Easier and alot cleaner install than having to bypass all the factory amps.
Old Sep 30, 2009 | 10:20 AM
w8lifter21's Avatar
That radio has 6 channel outputs. Front, rear, and subwoofer output, so you're good to go!
Old Oct 1, 2009 | 04:01 PM
icemanf14d's Avatar
Sunlit Sand Beauty
so anything with 3 outputs or more is good.?
and by the way...right now with the factory bose the sub isnt working and im guessing the amp isnt either..
will the sub work when connected to a new HU?
Old Oct 1, 2009 | 04:02 PM
icemanf14d's Avatar
Sunlit Sand Beauty
http://www.crutchfield.com/p_142C4NN...n-Adapter.html
is this what youre refering to....???
