Where to get door panel removal tool?
Old Nov 30, 2001 | 12:05 PM
JMAX95's Avatar
Does anyone know where I can get a cheap door panel removal tool? I just need something cheap that does the job.
Old Nov 30, 2001 | 12:44 PM
Whitemax's Avatar
Disco Biscuit
Crutchfield has them for $3. A long flat screwdriver will work as well......
Old Nov 30, 2001 | 02:47 PM
jmax
My Craftsman flathead works just fine.
Old Nov 30, 2001 | 04:36 PM
RidinOnChrome's Avatar
i didnt know there was such a tool.....
Old Nov 30, 2001 | 05:15 PM
mingo's Avatar
if you get a cheap tool like mine, make sure you grind down all the edges so it's nice and smooth so you reduce the chance of scratching the trim.
Old Dec 1, 2001 | 10:47 PM
ny96max's Avatar
all you need for the maxima is a simple panel tool. You can get one at any local hardware store. Looks like a mini panel tool, perfect for taking off the door handle cups, everything else is either screwed on or clipped on.
goodluck!
Ant
Old Dec 2, 2001 | 12:50 AM
chinaonnitrous1's Avatar
oh please.......just pull.make sure all the screws are out..and start at the bottom corner.......pull..pull and pull some more..and *pop* *pop* the clips will come out...if the clips get stuck in the door..just pry them out and slide them back into the door panel.......but if ya'll dont have enough strength in your fingers...a screwdriver will work..very carefully....pry it up.and use your fingers to pull the door off....
ef9
Sep 29, 2015 11:29 PM
95naSTA
Sep 21, 2015 06:50 PM
carid
Sep 17, 2015 05:00 AM
Colossus
Sep 9, 2015 05:46 AM
