Ground Hood switch?
Old Oct 16, 2009 | 06:44 PM
jr schultz's Avatar
Ground Hood switch?
The remote starter I bought has a negative input hood switch that is required to be hooked up. Can I just hook this to ground and not have the switch since it's negative input?
Old Oct 16, 2009 | 08:31 PM
DcMaN's Avatar
you can put it to a ground, and it will always think that the hood is closed, so it will be able to start with the hood being open. There for defeating one of the main purposes for the hood pin switch. The other purpose is to let the alarm know that the hood has been opened while the alarm was armed. Run a wire out to the car, and tap into it directly at the hood pin switch on the drivers side. There should be two wires a black wire which is the ground input, and a colored wire that is youre negative trigger, connect youre hood pin wire from the alarm to the colored wire at the hood pin switch.
Old Oct 19, 2009 | 11:41 AM
djfrestyl's Avatar
Suspension Yoda
Agree, your car already has a hood pin switch. Why not just use it?
gavin68
Sep 18, 2021 12:36 PM
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
howardis
Dec 11, 2019 06:10 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
