Wiring Guru's help needed!
Old Dec 16, 2009 | 05:02 PM
oxygen's Avatar
OK I made a video of this because it was too hard to try and explain without people thinking I'm crazy.
http://www.youtube.com/watch?v=mDCruFkhOec
The camera SUCKS. Here's what happens. Wiring up a whelen slimlighter. Connect + and - wires on the bar itself to the battery, ALL LEDs work just fine! Works great! ... I connect the power wire from the light bar to a connection on a 3 prong switch, and a wire running from the + battery terminal to another prong on the switch. I run the ground directly to the battery in the deminstration...
What happens when I run the light bar to a switch is that only 8 LEDs on the bottom of each side of the light bar will light up.
Summary = battery directly = fine
Switch = only 8 LEDs light up on each side.
Switch is 20 amps. I ran the light bar to a 10 amp fuse in the engine compartment and it worked fine all LEDs lit up so I don't think its the switch itself,not sure
Old Dec 16, 2009 | 06:18 PM
oxygen's Avatar
problem solved! bad switch
Old Dec 16, 2009 | 06:23 PM
anomaly117's Avatar
that woulda been my guess
Old Dec 17, 2009 | 03:52 PM
abdel's Avatar
allite so check it my 4th gen is tripping i think the security system is stuck or something it wont start is there like a fuse or a way to disconect it.cuz its been doing this for two days .
smplyamzng
Dec 13, 2015 01:19 PM
TonyJr
Aug 20, 2015 12:14 AM
Viralkill
Aug 16, 2015 05:09 PM
doobadoo
Aug 15, 2015 06:43 PM
maximaham
Aug 7, 2015 01:11 PM
