Another Bose question
Old Dec 21, 2009 | 04:02 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
Bought a used Sub from another org member. Replaced mine and it didn't work. How can I test the Bose to see if it is working properly and also how to. I have no clue on what to do, electronics is not my strong..
Old Dec 21, 2009 | 06:07 PM
bigpopaj369's Avatar
sounds like ur having the same problem me and soo many others have had check this out http://forums.maxima.org/5th-generat...00-maxima.html i would bet that this is whats wrong with it. i just eliminated the whole plug
Old Dec 21, 2009 | 06:50 PM
Lontar1's Avatar
it was working for the other member and I dont doubt him...
Old Dec 22, 2009 | 12:14 PM
noo i was refering to the problem being in the circuit board that eliminates unwanted noise if u look in the thread i posted u wil lsee what i mean.
Old Dec 22, 2009 | 03:36 PM
Lontar1's Avatar
well, did the soldering on mine and it didnt work, i just added this new one and it didnt either.. so iguess no more Boom,Boom for me
Old Dec 22, 2009 | 05:15 PM
try to eliminate the plug completely just unplug them and then plug it back without the board see if that works
Old Dec 30, 2009 | 07:54 AM
Lontar1's Avatar
any 1 has another idea?
Old Dec 30, 2009 | 10:46 AM
life-rocks's Avatar
You can Buy a Cheap Amp & Keep the Factory Sub.
It is Simple to Wire.....
I Replaced the Amp and Sub....
Still using the Factory Wires w/ No Problems.
Old Jan 1, 2010 | 11:17 PM
Lontar1's Avatar
but the amp works..I think.. wil take it ot someone to check it out
Old Jan 2, 2010 | 05:55 PM
did u try eliminating the whole circuit board????? just unplug it all and plug the wires directly into each other leaving out the plug. try that before u take it somewheres
Old Jan 2, 2010 | 08:07 PM
choray911's Avatar
The Crazy Azz Cracka
If you want to check the sub you can use a 9 volt battery. Disconnect the sub from the amp and tap the speaker leads of the sub to the battery. If it doesnt pop, the sub is bad.
Old Feb 23, 2010 | 11:21 AM
01-maxima-24's Avatar
the sub is not the problem, its the relay in the amp. Im sending mine to the guys at Factory Car Stereo Repair, the web site is carstereohelp.com . They deal with this problem all the time and assured me its the amp. They're charging me $85 + shipping. Im shipping out today, Ill keep you posted on results.
Mar 12, 2020 12:06 AM
pears
Sep 18, 2015 05:25 AM
popdedop
Sep 11, 2015 11:17 AM
Johnny9595
Sep 3, 2015 05:18 AM
