Ok to use stock Bose wiring when replacing system?
Ok to use stock Bose wiring when replacing system? UPDATE: YES inside new FAQ w/ pics
Please excuse me if this has been answered before, But I did a search of the messages and the FAQ's but I still haven't found an answer to my question.
I have a Bose system in my '91 SE. I bought a new head unit and speakers all around: 6x9 rears, 6.5 fronts. Can I just install these parts and still use the stock bose wiring? I assume that I do not need the "bose harness adapter" because I will not be using the bose speaker amplifiers...right?
UPDATE. I have upgraded the system using the stock wiring. I did not need the expensive $60 Bose harness. I have also made a page regarding this issue since it seems like it is causing so much confusion. Click here:
http://www.frysinsider.com/maxima
Originally posted by ny96max
you need a Bose interface harness, they run around $60 and your good to go
So I still need the Bose interface harness even if I an not going to use any Bose parts anymore? I am taking out the Bose speakers/amplifiers and installing instead 4ohm speakers.
here is a good webpage that maybe should go into the FAQ section:
http://www.autotoys.com/New_Tech/Our...axima_bose.htm
Go here to find the proper wire locations on the harness.
I have 2 3rd gens and I have aftermarket systems in both using the bose wiring. No problems at all.
BTW I don't believe the bose harness has a ground wire.
Maxinesdaddy
Aug 21, 2015 11:43 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
kirkhilles
Aug 8, 2015 10:53 AM
