Car Audio Upgrade
Old Apr 2, 2010 | 08:22 PM
STILLENGLE's Avatar
Car Audio Upgrade
So iam getting tired of my BOSE cutting out, and I want to get a new stereo system.
I am looking at the Pioneer AVIC-X910B7 and some good speaker's what do you guys recommend?
I wanna keep my hands free controls as well, "steering wheel controls"
If anyone has suggestions let me know.
Old Apr 3, 2010 | 12:39 PM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
Ill admit that i was happy with my rainbow germanium setup with the dual 6.5s. in a properly sealed door they were decent. een just running a single pair for a bit actively.
other than that i was alot happier with the nobelliums, but i can also say that if you dont want to drop coin like that that you can get away with a set of the Polk Momos and be pretty good. I wasnt wild about the tweeter when i ran them, but the mid actually wasnt that bad considering what it cost me.
Other than that there is a set from pioneer that has gotten some really good reviews on the boards (ca.com) and arent too expensive. even cheaper there are ppi comps floating around on there that not too long ago were fairly cheap and can still be had for reasonable prices. recommend getting with 6spdcoupe (Don) if your gonna go extravagent, hell make it at least accessible if its too much most of the time lol. great guy. i drove to jersey to get mine when they came in and have dealt with him a few times. good guy.
Old Apr 6, 2010 | 01:50 PM
DBrames's Avatar
get a sub. it will make any type of music sound so much better. you dont have to blast it to make it sounds good
Old May 7, 2010 | 12:09 PM
tedo007's Avatar
faster than you think
I just bought Alpine CDA-105. It's still on the way to me. Hopefully sound good enough to run it for year and upgrade my speakers.
Old May 9, 2010 | 12:28 PM
djfrestyl's Avatar
Suspension Yoda
This is an old thread...but....
What's your budget? I have an Alpine CDA-9856 for sale if you're interested. And I'm in East Brunswick, not too far from Hamilton.
You'll need a PAC Steering Wheel Interface module to retain your steering wheel controls. They make them for most aftermarket decks out there.
Old Jun 15, 2010 | 05:36 PM
JordanBertini's Avatar
yeah a good sub will help make your system sound better
Old Jun 16, 2010 | 09:54 AM
tigersharkdude's Avatar
duh noob
Old Jun 16, 2010 | 05:18 PM
STILLENGLE's Avatar
duh noob
Iam dying in laughter. no seriously I am. I can't believe that wasn't sarcasim.
Old Jun 17, 2010 | 09:33 AM
would this have been better
"no **** sherlock"
Old Aug 3, 2010 | 12:02 PM
mitrals's Avatar
I have been trying to find a similar solution. I didnt get an answer in the FAQ so here it is again. Any help is hightly appreciated:
I have been on Maxima.org for the past couple of days trying to look for a solution for my 6th generation Max without Bose. Here is what I am looking for: I want to keep the original cd player as I do not like the aftermarket look. Plan of action is to get a PAC NIS2 and hook up my zune to it. A couple of my speakers are torn so I figured I would change them as well. I am looking for some help in the following:
1. I am planning to get 6.5" speakers for the front and rear doors. Will I need any adapters/mounting brackets or is it a simple swap. Crutchfield says I will have to splice the cable for the speakers. Is there any available harness? Also will a 4 ohm speaker do? I know the Bose system is 1 Ohm but I donno what the non bose speakers are.
2. The rear deck. This is where I am confused the most. Does my car come with a 6X9 or 8" subs? My plan is to replace them, get an amp to power them. Brings me back to the head unit: I do not think there is a line out. Should I use the wires that are going into the back speakers or should I buy a line out kit from PAC? I am not looking to add a sub box. I wanna keep the install as clean as possible.
Also are there are tutorials for me to open up the panels/console/rear deck? I have been finding everything for the 4th and the 5th generation.
Thanks for the help.
Old Aug 3, 2010 | 12:16 PM
djfrestyl's Avatar
Suspension Yoda
1. You'll need brackets for the speakers. Use MDF rings. If a harness exists, then Crutchfield would/should have it. So if they're telling you that you have to cut the two wires, then you likely have to cut because no adapter exists. Since you're non-Bose, you don't have a separate amp. Which means that your HU is the amplifier. It's running your speakers at standard 4ohm. You don't need a converter of any sort, just connect your aftermarket speakers (which are also a standard 4ohm) to the speaker wire.
No matter where you are in the car, the wires you use will be high-level. So either get an amp that has high level inputs, or get an LOC. Where you hook up the LOC is your choice. You can connect it behind your factory radio and run a long RCA to your amp. This method is best if you EVER plan on changing your radio, the RCA's will already be run for you.
Or you can connect it to the rear speakers and use a short RCA (assuming your amp will be in your trunk)
Where are you located?
Old Sep 15, 2010 | 02:52 PM
mitrals's Avatar
djfrestyl: Believe it or not the car does have an amp! Its between the 2 6X9s in the rear deck. My car speakers were cracking after sound was above 21, so I went ahead and got 3 sets of speakers (front and rear doors and rear deck) but the crackle continued. I unplugged the small amp in the back and I hear music from 4 speakers and not the rear deck. The crackle is gone now, but I have no bass at all now. The amp is factory and not aftermarket. (Clarion en-1204D). I am wondering if I should get a replacement from ebay (about 55 bucks) or should I get a small amp which I can power the rear deck 6X9. Not looking to spend too much.
Old Sep 15, 2010 | 03:53 PM
djfrestyl's Avatar
Suspension Yoda
If you don't want to spend much, then just get a replacement amp (same one).
Old Sep 16, 2010 | 01:27 PM
mitrals's Avatar
I was wondering if I can get a cheap amp with high level inputs. Also will I be able to run the power from the current harness and not run RCA (effectively eliminating the line out need from the stereo). Let me know. Thanks!
Old Sep 16, 2010 | 07:44 PM
Joeker82's Avatar
I'll add my two cents....You can buy a amp with high level inputs. But, it always sounds like crap. RCA's all the way. Really, you should just get a new headunit your already more than half way there. Your sound quality would drastically improve. Your cheating yourself at this point....IMO
Old Sep 17, 2010 | 06:10 AM
djfrestyl's Avatar
Suspension Yoda
Nope you can't do this. It's not the level of the signal, its the impedance of the amp. The bose system runs at 2ohms. Good luck finding an amp that will output for door speakers at 2 ohms. You'll either blow the amp, or blow the speakers. If you want to replace the amp, you HAVE to replace the speakers.
And I agree, run RCA's. The Bose HU outputs pre-amp line level signal.
Old Sep 17, 2010 | 10:32 AM
cerick01's Avatar
So I have an '08 Max and just had the Bose Factory Radio replaced with a Pioneer Avic x920bt with NIRD-01. They put in some high level to low level filters in the line (not sure if this is correct). Now it sounds MUCH worse than stock. I would have assumed replacing the head unit would have made everything sound much better. What is the correct way to replace just the head unit using the NIRD 01 interface, I miss my factory radio now...
Old Sep 17, 2010 | 02:02 PM
djfrestyl's Avatar
Suspension Yoda
They didn't install it right, take it back. Whatever converters they used either were not configured or wired properly, or simply not the right ones to use.
Old Sep 17, 2010 | 05:10 PM
Mistah_M's Avatar
when i had a blazer my bose BUMPED ppl heard me comin. when i got my 97 max se my radio didnt work right. i think it needed a new faceplate. but i wanted my alpine in anyways. i got that in n wat not but my speakers dont sound as good as it shud. i read that aftermarket decks put out too much for the speakers. 13 year old car anyways so i said screw it . im gonna save up money n maybe get some apline spr-17s. plus i got 2 10s ready to go in the back jus havent done it yet.
Old Sep 17, 2010 | 05:39 PM
yualreadyknow908's Avatar
if yu trying to have yur shyt to knock yu need a good radio..... good radio good sound ...... get pair of components in the front im big orion guy in the back get mids now yu can go with one 12 or two .... now yu need amp to power everything up 5 channel amp or go with set up of two amp .... 1 channel nd 4 channel nd yu should be good (alpine9887 radio) (orion xtr pro speakers) (sub orion) (amps orion)
Old Sep 17, 2010 | 06:01 PM
Joeker82's Avatar
??? What ??? Is this english?
Old Sep 18, 2010 | 08:33 AM
Mistah_M's Avatar
hahahhaha
to me it didnt make sense. maybe the amp part but thats about it. but im still goin wit gettin 4 alpines 2 in the front 2 in the back. then hookin up the subs.
Old Sep 18, 2010 | 09:48 AM
nismos14's Avatar
§è~® f®ÈÄk
lolz @ this thread.
Old Sep 18, 2010 | 04:40 PM
djfrestyl's Avatar
Suspension Yoda
Well, I tried to help and that didn't work, so I'm out of this thread. Good luck to all of you.
Old Dec 29, 2010 | 04:00 PM
to get the best sound out of yur systems yu need a good radio ...... alpine 9887 is amazin radio it have build in cross over....if yu dont know what cross over is ... yu can take out the bass out of yur speaker......yu dont need bass in yur car speaker let the sub do it all work ..... yu need 4channel power up yur car speakers.... nd dont go by the watt... go by rms .. the higher rms the better .... dont get cheap amp kit either yu need atleast 4g wire that more then enough to upgrade later on in the future meaning(more powerful amp or sub i spend 4g on my car systems alone...... just my front speaker alone are 350.......if yu need advice pm ill help yu out
Old Dec 30, 2010 | 05:20 AM
nismos14's Avatar
§è~® f®ÈÄk
What?
What did you spend $4g's on?
Old Dec 30, 2010 | 08:12 AM
radio speakers subs amps
Old Dec 30, 2010 | 08:45 AM
nismos14's Avatar
§è~® f®ÈÄk
ok.. what brands what model numbers?
Old Jan 17, 2011 | 07:20 PM
Lani's Avatar
pioneer pioneer pioneer could never go wrong with them or Kenwood receivers
Old Jan 17, 2011 | 08:10 PM
Joeker82's Avatar
SOMEBODY! Please, PM this guy for stereo help! HAHA! I think we should sticky this! This is some good s**t. Thanks!
Old Feb 18, 2011 | 09:06 AM
Mistah_M's Avatar
i think i need a new radio wit the crossover in it. cuz too much bass goes to my bose speakers n it sounds like crap. plus im thinkin of gettin a sellenium horn for high treb, **** is loud lol
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
09maxshawn11
Aug 14, 2015 10:07 PM
Slamrod
Aug 10, 2015 12:33 PM
MikesChevelle
Aug 9, 2015 11:50 AM
