MY max is MAXED!!
Old Dec 10, 2001 | 10:00 AM
hockeyghst's Avatar
MY max is MAXED!!
ok heres what happened.....i was drivng home from work and all of a sudden my cd player turned off.....i have an aftermarket pionner headunit....my tv also did not work anymore and my clock turned off.....i have a 95 gxe......so anyways i figured it was just s fuse...when i got home i checked all possible fuses and none were blown.....they were all good so i did not know what the problem was....i go to finid out that my windows and powerdoorlocks/keyless entry doesnt work........i have no idea whats wrong.......i guess i fried some wires but i dont know where to start....i know im not taking it to nissan thats for sure.........this really sux.....i havent had my radio in about a week and it sux cuz i need music..........if anyone knows where i cant start looking to fix this problem it would be great............thanx in advance guys........
Old Dec 10, 2001 | 01:45 PM
MaxDriver98's Avatar
Sounds like your system is too powerful for your battery.
Old Dec 10, 2001 | 08:12 PM
jmax
Actually it sound like the alternator is either fried or the connection has come loose. The battery must still have enough voltage to start the car but not enought to power any of the electrical devises. If nobody with a working alt believes this unplug the wiring harness and see how long your accessories still work. My headunit shuts off between 11 and 12 volts, so that still gives me enough battery time to pull off the road and get to a parking lot.
Old Dec 10, 2001 | 09:24 PM
hockeyghst's Avatar
no i have an 800watt amp from a flea market so i dont even think it is true 800 watts......
Old Dec 10, 2001 | 09:25 PM
hockeyghst's Avatar
i dont think its the alternator...i guess i should have been more specific.....all the other electrical parts work fine.......inside and out....headlights taillights blinkers indiglo guages hazzards defrosters the ac/heat the only think out is the cd player the clock and power dorrlocks/wondows........so not everything electricla is fried thats why this is buggin me so much......
Old Dec 10, 2001 | 10:53 PM
jmax
In that case it sounds like a relay but I don't now which one. There are several under the hood in plastic bins similar to the under hood fuse box. Opening the box may answer your question or spawn many new questions.
Old Dec 11, 2001 | 09:49 AM
hockeyghst's Avatar
where exactly are the relays under the hood.......???? im not usre if the things i checked wer ebig fuses or relays........thanx
Old Dec 12, 2001 | 06:11 PM
hockeyghst's Avatar
can you please tell me where the relays are located at???
Old Dec 14, 2001 | 12:03 PM
Blaximazx's Avatar
relay location
Try over by the windshield washer resevoir and also by the battery (i think) the best think is to check you owners manual, it goes into detail exactly where all of them a located and which relay is which.
Old Dec 15, 2001 | 02:39 PM
hockeyghst's Avatar
ok after 2 hrs of going through the wires i found out that all this crap was from a damn fuse.....well to tell u the truth the fuse was blown but for somereason when i used my fuse tester the light came on....needless to say i ripped out a lot of electrical **** that could have been avoided if i used my head a lil bit more.......
Old Dec 15, 2001 | 10:45 PM
hockeyghst's Avatar
ok its 12 43 am and i just got home from hoceky so i figured it would be a good time to put my cd player back into my car and everything is good until i turned on the radio....i couldnt hear anyhting from the speakers....i checked the wires in the back they are all taped up and i dont see any loose connections....i checked all my audio fuses and they seem to be ok........i dont know what going on this electricla problem was ****ing me off for a while i finally get it fixed and now i cant hear anything from my speakers so i do not know where to begin......maybe i hooked up the wires wrong from the cd player to the wiring harness??? i put the yellow memory wire to yellow off the harness then i put red and red together for power.....one red is accesories the other red was 12 volt power........and i connected the 3 blue remote wires........all the speaker wires are wired correctly.......i dont know what swrong can anyone help???
Old Dec 16, 2001 | 05:20 AM
jmax
Sorry, I don't have a copy of the wireing diagram laying aroung anywhere. But, just because you hvae wires color matched, that doesn't mean that it is right. I think the harness is probably Metra, and your headunit is Pioneer. I would definitely recheck your wiring to make sure you have power and everything else going to the right place on the headunit. I know I have had two or three HU's that used at least one yellow for power or memory power - that's what supplies powers to the clock and presets.
Old Dec 18, 2001 | 10:25 AM
hockeyghst's Avatar
i knwo that the colors do not always go to gether but i just figured u guys knew what i meant.......n e way i double checked my connections and still no sound from speakers.........cd player works and the pre sets save when the car is turned of so i know the power and memort wire ar hooked up correctly.......still no sound though......
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
maxima297
Sep 30, 2015 03:32 PM
