new double din installed with components question
Old May 28, 2010 | 07:23 PM
El_PrOfE's Avatar
i just got a double din installed this weekend i also took the liberty of upgrading my internal mids and high and i got a component set for the front. i got a set of jl audios.after install i was happy to get my double din going. once i got in the car i tested it out and it was all working well but now my volume is cranked up to max and it is lower than my old factory bose set up. now since i only did the front and not the rear would that have an effect on volume? also i am running 2 12's kickers with a 800 watt amp and no amp for the mids and highs. any suggestions or comments? i need to know why the new set up is not as loud as my old factory one. thanks.
Old Jun 1, 2010 | 07:53 AM
nismos14's Avatar
§è~® f®ÈÄk
No it wouldn't. Are the jl's being powered by the bose amp? If so and if not, they should have an amp on them.
Old Jun 4, 2010 | 07:27 PM
El_PrOfE's Avatar
they r powered with the bose amp
Old Jun 4, 2010 | 07:53 PM
djkevinnn's Avatar
i don't think you should run them off of the bose amp.
i'm not sure of the impedance of bose amp, but it might run differently than what the JLs take
if you really want to enjoy those JLs though, get an amp on them, but for now, run them from your double din
Old Jun 4, 2010 | 07:59 PM
El_PrOfE's Avatar
i was going to get a amp for the mids and highs and a capacitor since i am also pushing 2 12's . but i fell into some cash flow problems so i guess i am right like this for a little while also i will get the component set for the rear.
Old Jun 4, 2010 | 09:21 PM
nismos14's Avatar
§è~® f®ÈÄk
Don't get a cap, and you can't run other speakers off the bose amp the resistance is wrong for them. That's your low volume problem.
Old Jun 6, 2010 | 12:46 AM
AscendantMax's Avatar
get a dedicated amp for them.
Old Jun 30, 2010 | 01:27 PM
Afronaut's Avatar
Active procrastinator
You can run aftermarket components off the Bose amp. I replaced my front speakers in my 2K Maxima with Polk components and things have been fine for the last two years. You should go back over the wiring from your headunit to ensure nothing as come loose. Also if you have the resources, try another headunit to see if still have the same problem. I hope this helps.
Old Jul 6, 2010 | 04:28 PM
Afronaut's Avatar
Did u get ur problem fixed?
Old Sep 15, 2010 | 08:31 AM
El_PrOfE's Avatar
no the sound is still low, i think i just went to a crappy place cus the headunit has a bass control but they said they could not get the base to work with it. i might have to bite the bullet and go elsewhere to see what the problem is, i just do not want to pay out the nose . sorry to grave dig. but i also remember the components i got they are the jl audio TR650-CSi since i am adding components to the back what kind of amp should i be looking to get? thank you in advance.
Old Sep 15, 2010 | 09:24 AM
ICEMAN76's Avatar
^^+100
Yes, you can run aftermarket speakers on the bose amps. The problem with that is the bose amps are a 1 possibly a 2 ohm amp. If you run 4 ohm components on it you will lose sound. More resistance equals less volume. Correct me if I'm wrong gents.
Old Sep 20, 2010 | 08:22 PM
El_PrOfE's Avatar
thanks for the replies, in terms of an amp for the components what should i be looking at 2 ch, 4 ch?
Old Sep 20, 2010 | 08:44 PM
Joeker82's Avatar
Depends on how many speakers your running?? 2 channel...2 Speakers...4 channel...4 speakers.
ekrunch's Avatar
Have you considered just using the power of the new radio to run the new components? Granted, I'm all for using amplifiers and such, but if you're looking for low cost options then using the deck power might be one. (Depending on how much power those new speakers need, etc) You'll most likely have to run new wires from the head unit to the speaker locations, which sucks, but it's the best way to do it.
If you want an amplifier because you'd like to improve the sound, there are a lot of great options. For small space requirements, check out the XD series from JL Audio. For sound quality, there are some great amplifiers from Arc Audio, JL, Zapco, Audison, etc. Plenty of choices to meet your needs!
Old Sep 21, 2010 | 05:52 PM
mendon99's Avatar
tastey wheat
Id also suggest bypassing the BLOSE amp for now (running the comps straight from the pioneer) until you can afford a multi channel a/m amp.
Old Sep 23, 2010 | 06:48 AM
ICEMAN76's Avatar
We the people of the .ORG agree.
Old Sep 28, 2010 | 09:01 PM
El_PrOfE's Avatar
this is the component set i bought for the front speakers.
http://mobile.jlaudio.com/products_c...hp?comp_id=125i will purchase the same set for the bank. so i will have to buy a 4 chanel amp right since im running 2 sets of components.
Old Sep 28, 2010 | 09:07 PM
Joeker82's Avatar
Correct! Those are nice speakers. Good choice! You may want to look into a 5 channel. That way you can run a sub also. If your planning on doing that down the road....
Old Sep 28, 2010 | 09:15 PM
El_PrOfE's Avatar
thanks, i already have an amp for my subs im pushing a pioneer amp for my 2 12's but im looking into something with more kick. thanks for the replies. i will get the other set asap as well as go amp shopping this weekend.
Old Sep 29, 2010 | 08:24 PM
Joeker82's Avatar
Enjoy buddy!
Let us know how the install goes?
PH98I30
Jan 9, 2025 08:08 AM
Roman777NYC
Nov 7, 2015 10:13 PM
95Maxi
35
Sep 2, 2015 10:37 AM
