CAN SUB CAUSE PROTECT MODE
Old May 29, 2010 | 09:20 AM
cmd26's Avatar
I have a cerwin vega that wprked for a week hit hard too. Now it causes my amp to go into protect mode, i thought my amp was broke but i hooked the sub up to mt brothers amp and the same thing happened. Im wondering if maybe i wired it wrong or is something messed up on the sub?
Old May 29, 2010 | 09:23 AM
cmd26's Avatar
sorry for the double post delete this thread pleez
Old May 29, 2010 | 10:46 AM
AscendantMax's Avatar
yep, sure can. the sub can be wired too low of an impedance for the amp to safely handle.
Old May 29, 2010 | 02:19 PM
cmd26's Avatar
My setup 1 4ohm sub w dual voice coils 500 rms 1000 watts the amp is bridge p5002 250 rms 500 watts. I kno the amp isn't as strong as the sub but it sounded great until it stopped working.
Old May 29, 2010 | 02:24 PM
eng92's Avatar
If the amps go into protect mode as soon as they are turned on with that sub connected, you have a direct short. (ie. coil is shorted).
Try just hooking up one of the coils at a time to your amp or put a meter on them.
Old May 29, 2010 | 02:32 PM
eng92's Avatar
It is your thread, you can delete it yourself (under thread tools)
You should delete the other one. It does not have any responses.
Old May 29, 2010 | 06:37 PM
cmd26's Avatar
it doesnt go into protect right away when i was trying to asjust the bass gain and frequency or when i turn the volume up around 16 or 20 it goes into protect.
Old May 29, 2010 | 08:59 PM
eng92's Avatar
Well I guess the impedance is below what the amps are "happy" with.
Do you have an ohm meter? I would measure the DC resistance of each of the coils separately and compare it against mfr spec.
Old Jun 24, 2010 | 10:52 PM
locknuts27's Avatar
Like most of the guys here I would say check the ohm or impedance rating on your amp. See if it matches it to your sub. Then rewire it, if it's dual voice coil keep it at single as this would raise your impedance!
Rule of thumb for amp, you can always run more power (as you can turn your gain down) but never under power your speakers.
Old Jun 24, 2010 | 10:53 PM
locknuts27's Avatar
Just out of curiosity, is there a difference between dc and ac resistance?
Old Jun 25, 2010 | 08:10 PM
cmd26's Avatar
Sub is trashed it started sounding like paper blowing in front of a fan. It still had some bass to it but I think its done. New problem Ive had this HU for like 6 years alpine cd-9825, it over heated cutoff and the screen said hi temp so im guessing its time for a new HU
Old Jun 25, 2010 | 09:45 PM
locknuts27's Avatar
Well at least you got your moneys worth!
Old Jun 30, 2010 | 07:18 PM
cmd26's Avatar
Just noticed the copper coil above thw magnet is gone.
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
carid
Sep 17, 2015 05:00 AM
pktaske
Sep 4, 2015 08:40 AM
