10 Inch sub in stock bose Hole
Old 07-06-2010 | 03:27 PM
V2subzero's Avatar
Do you think it would be possible to fit a 10in sub in the stock bose box in the rear deck any possible problems you can think that would come from that? i was thinking cut out enough space for the sub drill a sub box into kinda hanging in the air in the trunk since its kinda a free air. if any one else has done this or anything
Old 07-15-2010 | 07:27 PM
Maxy91's Avatar
Wont work, would need to cut some metal to make a large circle. And would have to under mount the sub to the rear deck.
Old 07-20-2010 | 10:08 PM
nismopc's Avatar
Yes it's possible and can be mounted from the top, not bottom. This way no need to remove the trunk pressure rods.
10" Kicker Comp free-air in my 2003 Max SE...
and after I covered rear deck with black carpet...
Old 07-20-2010 | 10:09 PM
nismopc's Avatar
I trimmed the 8" OEM hole to accomodate the 10" Kicker.
Just an FYI. I did not have the Bose, but as you can see, the opening is the same.
Old 07-21-2010 | 09:55 AM
MadMax07SL's Avatar
That looks really good. How does it sound with the sub right there inside the cabin?
Old 07-21-2010 | 03:19 PM
nismopc's Avatar
Gives me a nice bass response and a full trunk. win win
Old 07-21-2010 | 05:39 PM
V2subzero's Avatar
how is the free air sub? good bass quailty? I rellay would rather have a enclosed but i was thinking that the trunk rods might get in the way
Old 07-21-2010 | 07:37 PM
nismopc's Avatar
The quality is really good as should be expected from free-air, but it's in no way a SPL set-up. If your wanting big bass that can be heard 3 miles away and shake the dust off granny's boot as you drive by, it aint gonna happen.
Old 08-14-2010 | 01:49 AM
ICEMAN76's Avatar
Can you use any sub as a "Free Air" sub? I.E. Can I stick a Memphis Mojo in there and expect good results? Don't you need alot more power to the sub with this application?
Old 08-16-2010 | 10:14 AM
Afronaut's Avatar
Active procrastinator
For best results don't use just any sub, some subs are engineered to work better in an infinite baffle configuration. Do a google search for the subs
Old 08-16-2010 | 10:18 AM
ICEMAN76's Avatar
I was talking to Don, and he suggested the DLS OA8 or OA10.
9aj9
04-05-2020 01:11 AM
max ride 41
09-17-2015 07:17 PM
Maxboy23
51
09-15-2015 02:20 AM
Maxboy23
09-04-2015 07:04 PM
