Subwoofer Boxes
Old Dec 17, 2001 | 04:27 PM
TWright517's Avatar
Subwoofer Boxes
Ok.. I have:
Sony 1000 watt class d amp
2 12" Nakamichi's
and.... then comes the box... right now i have a dual bandpass box picked out, but im gonna ask yall for opinions. whats the difference between bandpass boxes and normal boxes? and if i get a normal box, im afraid to put anything in the trunk because the subs are exposed to being punctured. everyone, please post opinions on the different types of boxes and what box i should get
Old Dec 17, 2001 | 08:35 PM
jmax
First of all not every sub will work in every box. The box needs to be built for a particular subs various T/S parameters. That being said, bass heads typically like bandpass or vented boxes. Sealed gives the least output, but the most accurate. That's if we leave out AP and free air.
Old Dec 18, 2001 | 04:25 AM
TWright517's Avatar
Ok.... i think im going with sealed. is there anything i could cover the subs with so they wont get punctured?
Old Dec 18, 2001 | 05:43 AM
jmax
You could make your own grill out of metal screening, perforated metal or plastic, or you could buy a set of factory-same brand as sub or universal aftermarket grills.
Old Dec 18, 2001 | 03:29 PM
TWright517's Avatar
Where can i find these grills?
Old Dec 18, 2001 | 07:00 PM
deezo's Avatar
If you have a shop you deal with a lot, they should give them to you for free. I bought a sealed 12" bos for $20 and got the grill for free because I let them do my installs.
Old Dec 18, 2001 | 08:24 PM
Y2KMaxGXE-R's Avatar
It is up to the music you're listening to. I went with bandpass, it makes your bass sound bigger.
Old Dec 19, 2001 | 12:05 AM
Nismo's Avatar
I also went with dual bandpass because my current subs cant take alot of power so its the most efficient way for them to work and it moves alot of air with a bandpass without alot of power. When I get some better subs then I will switch over to sealed or maybe a custom tuned vented enclosure.
Old Dec 19, 2001 | 04:50 AM
TWright517's Avatar
I listen to rap and rap only... and i want the subs to hit hard, but i think im goin with sealed because 1000 watts is enough for me.
Old Dec 19, 2001 | 08:04 PM
TWright517's Avatar
I got my **** put in, i got a sealed box with the other stuff listed above. thanks for the advise. if sounds so frikin tight now. those nakamichis hit HARD. it sounds great. thanks for the help
Now i can nod my frikin head
peace
MaxiNoob98
Oct 2, 2015 10:13 PM
sliptap
Sep 30, 2015 05:57 AM
Sep 27, 2015 08:37 AM
Stagnet04
Sep 14, 2015 11:28 PM
