Subs and headunit help
Old Dec 26, 2010 | 01:58 PM
xtremepb0's Avatar
I got a clarion cz500 and 2 12 inch visonik subs and this will be my first audio install. I get how to do most of it but i was wondering how do i remove the stock bose headunit in my 98 maxima? also where is the best place in the fire wall on the drivers side to run the power cord from my battery to amp? adn then where is the best place on the passenger side fire wall to run my subs to my headunit... the reason im doing the power cord and amp to headunit cord on different sides is because i heard if you run them on the same side you get a lot of interfearence..
-thanks guys
Old Dec 26, 2010 | 02:22 PM
xtremepb0's Avatar
also where is a good spot to put my amp and ground wire?
Old Dec 27, 2010 | 12:28 AM
AscendantMax's Avatar
The interference is often caused by poorly shielded (cheap) signal cables and/or bad grounds.
But you can ground the amp to any solid piece of metal in the trunk. I used the spare tire well, sanded the grounding point down to bare metal, and secured it with a bolt and locking nut. Make sure the grounding point is free of dirty/grease/paint. Some people will say to ground at the seat belt bolts, but the stuff they use to help secure the bolt like loctite can hinder a good connection.
Old Dec 27, 2010 | 02:06 PM
xtremepb0's Avatar
Alright, also i just looked at my headunit.. Clarion cz500 adn for the RCA cables from the subs it has 2 plugs. SUB 1 and SUB 2. Which one is the right and which one is the left lol
Old Dec 31, 2010 | 04:39 PM
locknuts27's Avatar
What are the color schemes? See if it matches the other sets, red and white (should be labled which is left or right).
Old Jan 2, 2011 | 10:05 AM
xtremepb0's Avatar
They are both colored purple. I'll plug them in and hope for the best
xtremepb0's Avatar
And as for labeling it just says sub 1 and sub 2
Old Jan 3, 2011 | 07:22 AM
nismos14's Avatar
§è~® f®ÈÄk
Doesn't matter since sub output will be mono anyway.
Old Jan 7, 2011 | 04:44 PM
locknuts27's Avatar
ha ha good point
Excalibur23
Oct 13, 2015 04:33 PM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Taino14
Sep 24, 2015 02:51 PM
ballerchris510
Sep 23, 2015 08:46 PM
