Replace Bose amp
Old Dec 28, 2010 | 06:05 PM
Pfc Woody's Avatar
Replace Bose amp
Im thinking that my next step for my stereo is going to be replacing the bose amp with something a little better, most likely a fosgate. My question lies in how difficult would it be to get the speaker wires from this amp? I had a high low converter wired in for my subs so I'm going to use that for the rca's. my only question comes to how hard is it and if not hard which wires is it on the bose amp?
Thanks ahead guys!
Old Dec 28, 2010 | 07:07 PM
BLACKKILA.GTR's Avatar
oh oh... i had to bypass the whole boss system....smh good luck man
Old Dec 31, 2010 | 05:58 AM
djfrestyl's Avatar
Suspension Yoda
You can't just replace the amp. You'd have to replace the Bose speakers with it.
Have you replaced your head unit yet? That should be the first step you take in replacing your system.
We need more info about your current setup (and how it's wired) so we can give you proper guidance.
Old Jun 3, 2011 | 10:25 PM
yankeefan13's Avatar
I know this is an old thread, but I want to replace my amp also I have a kenwood HU the rest is stock bose. What can I do?
Old Jun 4, 2011 | 05:12 AM
djfrestyl's Avatar
Suspension Yoda
If you want to replace the Bose amp, the speakers have to be replaced with aftermarket as well.
Old Jun 4, 2011 | 10:02 AM
Damn.. okay though pretty much I should just get an whole new sound system
Old Jun 4, 2011 | 03:45 PM
djfrestyl's Avatar
Suspension Yoda
If the aftrmarket HU is insufficient, yea, replace all 4 speakers and amp, and run all new wiring.
Old Jan 16, 2013 | 09:59 PM
mrfixit81's Avatar
Amp
I know this is kinda old but Im wondering where the amp is in the maxima? I belive mine has gone out and I have no idea where to find it!
Old Jan 16, 2013 | 10:48 PM
rebelhell's Avatar
Usually under the rear deck in the trunk. What year max?
Old Jan 17, 2013 | 10:02 AM
mrfixit81's Avatar
Sweet I found it. It's a 2006 3.5 SE. I'm working on getting my system hooked up. But all of a sudden the speakers start making a poping sound and play no music? This only happens if I leave the radio on when I turn the car off. I've been told it's most likely my amp but I don't know yet.
Old Jan 17, 2013 | 10:20 AM
djfrestyl's Avatar
Suspension Yoda
It's your HU. Happens with certain decks. Not much you can do about it.
You sure it's wired properly?
Old Jan 17, 2013 | 09:55 PM
mrfixit81's Avatar
So you think the amp is ok? Is the HU the screen?
Old Jan 18, 2013 | 07:14 AM
djfrestyl's Avatar
Suspension Yoda
Helps if you tell us what exactly you're installing and how- that way we can identify the culprit.
Old Jan 18, 2013 | 07:18 AM
Kelton_jj's Avatar
I didn't even bother with a low converter. I just replaced all the speakers and the headunit. Then I ran all of my speakers of an amp. It's not hard to run the speaker wires. But it can be a pain.
Old Jan 26, 2013 | 11:56 AM
mrfixit81's Avatar
I am just running the stock bose set up. I haven't got anything else hooked up til I fix the speakers popping.
Old Jan 26, 2013 | 12:01 PM
djfrestyl's Avatar
Suspension Yoda
Then it's definitely your HU. As mentioned, it happens sometimes. Just the way the head unit behaves. Nothing you can do about it unless you change out your amp and speakers..or head unit.
6spd4dsc
May 9, 2022 12:30 PM
melteye
May 16, 2016 12:02 AM
2k11ApexEvo
Mar 30, 2016 06:54 PM
homeyclaus
Sep 3, 2015 06:15 PM
Maxinesdaddy
Aug 21, 2015 11:43 PM
