making my own rca patch cords....
Old Dec 23, 2001 | 12:21 AM
Yellowbrother's Avatar
i have some questions....
1. about roughly what guage is each wire in a standard rca patch cord???
2. i'm planning on using cat 5 cable to make these rca patch cord....should i make one cord with all 4 pairs in that cat 5 or make a one pair with the 4 pairs in the cat 5(two pairs per cord)???
3. in theory cat 5 is suppose to reduce induction of noise for high speed data transfer...will this same theory work for car audio purposes???
4. or should i just make the rca patch cord out of speaker wires???
5. in the standard rca patch cord....are they twisted internally??? never cut one apart to examine it...but i do know that each cord contains two wires...so one pair contains 4 wires....
Old Dec 23, 2001 | 06:52 AM
jmax
Go to www.elitecaraudio.com
In the SQ forum there is a very long post about wiring.
Old Dec 23, 2001 | 10:08 PM
speednsound007's Avatar
Just wondering
Why do you want to make your own patch cords?
PJ
Old Dec 24, 2001 | 03:34 PM
ABS's Avatar
ABS
Category 5 Cable has been used for lots of wiring in home audio, including patch cables, in the past. I do not have a lot of detail regarding how many twisted pairs you should be using. However, I would recommend that you use shielded Cat 5 vs. unshielded Cat 5. This will further reduce the liklihood of you picking up any EMI through the run. You might post the same question on some of the Hi-Fi forums/newsgroups and see what response you get. Good luck!
Old Dec 24, 2001 | 07:40 PM
Re: Just wondering
PJ
cuz the cost of good patch cord cost $$$$...i have unlimited access to cat 5....
Old Dec 24, 2001 | 09:46 PM
ABS's Avatar
ABS
Detailed Info
Check out this link:
http://www.carsound.com/cgi-bin/ubbc...=1&t=010481&p=
knight_yyz
Nov 6, 2015 02:34 PM
knight_yyz
Oct 24, 2015 08:05 AM
