PAC SWI-PS wiring on 2003 Maxima with Pioneer AVIC-D3
Hey guys!
Just received the final part of my stereo install and have a question.
In the paper that came with the SWI-PS it says:
HOWEVER, on the PAC website the info is a little different (link):
As you see, on the website it does NOT say to add a 47ohm resistor to pin26. Can someone please confirm if the 47ohm resistor is needed?
Thanks.
Code:
- Connect 150ohm resistor to Blue/Yellow wire - Connect 47ohm resistor to Green/Black or Red wire - Connect free ends or resistors to the interfaces White wire - Connect Brown/White to ground
Code:
- Connect a 150 ohm resistor to pin 27 (blue/yellow) - Connect the free ends of the resistors to the INTERFACE'S White wire - Connect pin pin 26 (green/black or red) in the vehicle connector to INTERFACE'S White wire - Connect pin 29 (brown/white) in the vehicle connector to Ground
Thanks.
Thank you so much for many useful responses and ideas! LOL
I went ahead and put that 47ohm resistor in there (pin 26) along with 150ohm resistor (pin 27), everything seems to work fine. Programming of SWI-PS is NOT tricky at all as some say - just re-read the instructions a couple of times if you do not understand them, it is very straight-forward!
Tee-hee!
Tee-hee!
wingsfan24
Aug 15, 2015 07:35 PM
bassmann
Aug 3, 2015 07:53 PM
