dynamat on rear deck....
Old Dec 28, 2001 | 11:42 AM
MaxedOut2g's Avatar
whats the easiest way to access the rear deck to put on sum extreme dynamat? my box is too high to just put it straight on through the trunk and i dont really wanna take it out unless i have to...is it possible to remove the rear deck, dynamat it, and put it back on or am i smoking something i shouldnt be?
atw
Old Dec 28, 2001 | 11:59 AM
maximadave's Avatar
detailerdaveb@gmail.com
Re: dynamat on rear deck....
atw
Clean out every square inch of your trunk and clean it. Yes clean it. Sound deadening material works best when the surface is clean. Smoke whatever you want. I had to smoke in order to put the Dynamat in my trunk due to my herniated disc in my back
Maximadave
Old Dec 28, 2001 | 11:50 PM
ny96max's Avatar
remove back seat and pull off your rear deck and your good to go!
Old Dec 29, 2001 | 01:38 AM
MaxedOut2g's Avatar
do i juss pull off the rear deck? like pull from top, push from bottom, i really dont feel like having 2 rear decks after trying to take the 1 off....any help appreciated...
atw
Old Dec 29, 2001 | 08:31 AM
jmax
There is a press board cover over the metal rear deck. The press board is held in place with plastic push pins. Remove the board as described above, clean the deck, clean the deck two more times, and cover with your damping material. You can also adhere a thin layer of carpet padding to the underside of the press board.
Old Dec 30, 2001 | 01:28 AM
SWEETSOUND2001's Avatar
Don't buy dynamat extreme. Raam mat is the same exact thing and can be bought for a dollar per foot. Email Raam@raamaudio.com Guy's name is Rick McCallum. He should hook you up for $55 + shipping per roll. You can visit my website for pictures of rear deck sound deadening. I have like 5 layers on there
Anton
Old Dec 6, 2009 | 03:50 PM
cgillie's Avatar
do you have to take the c pillars out to take off the carpeted deck? and if not where are the clips located?
Old Dec 6, 2009 | 06:07 PM
AscendantMax's Avatar
holy cow this is an old thread!
but yes you have to take off the c-pillars to take off the rear deck. they're just all clips spread along the deck so just pop them out carefully...just be patient about it
what year maxima? careful when trying to take out the rear c-pillars if you have a 6th gen. i'm not sure how it's like on other gens, but on the 6th gen...there are high pressure canisters for the side curtain airbags. so don't simply stab something back there and pry around randomly.
Old Dec 6, 2009 | 07:12 PM
Conrad283's Avatar
I need a truck
The search is broken ... It's coming up primarily with old *** threads.
Old Dec 9, 2009 | 04:43 AM
vball_max's Avatar
Here is a how-to:
http://shiftice.com/bose_deck_fix.html
You may want to bookmark this site. Lots of great information.
matts95max
Apr 23, 2025 10:44 AM
GregL65
Jan 17, 2020 08:01 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
bbsitum
Sep 11, 2015 04:55 PM
