headunit mod shop
Old Aug 24, 2011 | 07:16 AM
boost4age's Avatar
headunit mod shop
Can anyone recommend a shop or member here that's in the tampa area that could do a bypass so that video will work without the parking break being up?
I have a navigation app (Motion X drive) on my iphone but it won't work unless the parking break is up
Old Aug 24, 2011 | 08:50 AM
mendon99's Avatar
tastey wheat
what radio?
Old Aug 24, 2011 | 08:51 AM
boost4age's Avatar
pioneer avh-3300bt
Old Aug 24, 2011 | 08:58 AM
mendon99's Avatar
tastey wheat
you'll need a 12v relay. run the parking wire (lt green) to pin 30, ground both pins 87 and 86, run the remote (blue/white) to 85. 87a (center) won't be used.
or, wait for a tampa member to chime in. Im sure someone could help you but I'm sure you could do this
Old Aug 27, 2011 | 04:50 PM
AUDIOSPA's Avatar
Theres a mechanical piece in this radio that does not allow for relay switches to work. They work but only up to 10mph it has a built in accelerometer. Since the app uses built in equipment of the radio it will knock it down. Im not 100% sure if there is a software hack yet. I looked and I couldn't find anything hope this helps.
Old Aug 27, 2011 | 05:28 PM
boost4age's Avatar
yeah the installer mentioned that but he wasnt sure if this unit had it or not. i find this to be ridiculous i cant use my navi app cause it thinks it a video
Old Aug 27, 2011 | 06:28 PM
michael454rs's Avatar
Had 3 indash dvd one was alpine pioneer and a kendwood and all i did on all 3 was ground the wire thats goes to the parking break and it all good
Old Aug 29, 2011 | 06:05 AM
djfrestyl's Avatar
Suspension Yoda
^^ Read the 2 posts above yours. The newer units have other engineering in them that prevent electrical workarounds to work.
Also, sent you PM re: spare tire cover a while back, never heard from you. Requesting the courtesy of a response at least.
Old Aug 29, 2011 | 07:19 AM
mendon99's Avatar
tastey wheat
I'm fairly certain this mechanical piece you speak of is ONLY in the Pioneer NAV units, where you have to move a pin and ground it as well as ground another wire. Any DD Pioneer screen without NAV built in you can just use a relay and it will fully bypass.
Old Aug 29, 2011 | 07:21 AM
mendon99's Avatar
tastey wheat
1/3 correct. Any new Alpine is going to require a Pac TR7 to bypass video, pioneers you must either move pins or add a relay, and Kenwoods, yes all you need to do is ground a wire.
HOKUSMAX
Nov 13, 2017 04:34 AM
RealityCheck
Oct 2, 2015 06:34 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Sep 27, 2015 08:37 AM
