Installing a Sub/amp in a Bose 5th gen, needing additional guidance.
Old Aug 24, 2011 | 09:48 AM
DCZC's Avatar
After searching and building a game plan in my head. I wanted to get some feedback from others who have installed a sub.
Method: I plan to tap into the low line outputs from the factory bose setup
First question:
Should I tap in to the sub input leads? (see pic)
or should I tap into thee H/U?
Also, is the signal received sufficient to feed into a crossover?
I Currently have two amps and a sub.
Amps:
Coustic 241SE (240w rms)
and
Eclipse 3640 4/3/2 CH amp
60x4 rms or 105 x 2 @ 2 Ohms rms
Sub: Diamond Audio Cm308D2 (8" DVC @ 2OHM)
If I run no crossover I'll need to use the Eclipse amp bridged, as the built in crossover in the coustic no longer filters (full range only)
If I purchase a crossover I am considering using the 4 ch for a 4 pack and the coustic for the sub
Thanks for input
DC
Old Aug 24, 2011 | 12:44 PM
djfrestyl's Avatar
Suspension Yoda
Before I give my input, two questions:
1. Where is your current aftermarket amp tapped into?
2. Why do you not have an aftermarket head unit yet?
Old Aug 24, 2011 | 12:47 PM
DCZC's Avatar
All stock currently,
I'm wanting to keep stock mids/highs for now and install the sub and maybe some 6x9's (the proposed 4pk option) custom fitted in rear deck. My sub will be in a seal enclosure .62 cuft build to spec.
Old Aug 24, 2011 | 01:27 PM
djfrestyl's Avatar
Suspension Yoda
Get a HU first. Seriously. It will make your existing Bose system sound a lot better, and for when you're ready for aftermarket, its already got the proper connections needed for aftermarket amps/speakers.
Don't get 6x9's. Don't cut your rear deck. Music is produced and reproduced in a circular fashion. (think drums, trombone, etc..all circular output). If you need more 'bump' from your 6.5's, then upgrade to 8's in the doors. It's doable.
Old Sep 4, 2011 | 08:35 PM
pahanorlando's Avatar
This guide might help you
http://www.cardomain.com/ride/143972...-maxima/page-9
smplyamzng
Dec 13, 2015 01:19 PM
Finkle
Sep 27, 2015 09:53 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
TonyJr
Aug 20, 2015 12:14 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
