dei alarm zone 1 false error?
hey guys i have a viper 560xv. it had the 474v 4 button 1 way remote, and it worked fine. so i came across a sst responder 7701v remote, and antenna to accommodate. (pulled from a viper alarm/remote start as well) it works fine and is a great addition to my unit, except the issue i have is upon arming, occasionally the siren chirps twice, and the remote is telling me that sensor 1 (shock sensor) is being bypassed, OR it will arm normally, with the siren chirping once, and still the remote tells me upon arming that its "sensor 1", (shock sensor)
has anyone else had this issue? i tagged the wire from the kick panel, not the bcm. is it the bcm that is giving me a false reading? the brain is not near my lower hvac vents, so excessive heat or a/c by the unit is not a cause of damage to the brain.
Have you checked the switch for the trunk light? See if any voltage is going through it with the trunk closed. Measure for voltage at the trunk light. It might not be enough to make the light come on but the alarm could be sensing a small current draw.
no luck as of still. however i edited my original post after reading over it. the chirp on my remote is telling me sensor 1, (not zone 1 as i got confused) is being bypassed. sensor 1 is the shock sensor. however it works at all times. im a lil confused on this. im kicking myself cuz i came across an older shock sensor that would work fine to swap but threw it out.
hayne
Oct 5, 2015 11:53 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
