Please help with window issues
Old Dec 6, 2011 | 11:30 PM
Ricksi30's Avatar
So I have searched and searched and can't find a straight answer to my problem. I drive a 1996 I30 and my passenger windows in the front and back will not work. I cant get them to go down from the driver switch or the switch on either door. It has been like this for some time now and I've finally gotten to the point where I NEED to fix it. This occurred when I had my alarm installed and the installer said I need to replace the window switch at each door. Is this correct? It is not the regulators.
I would really appreciate any help.
Thanks, Rick
Old Jan 9, 2012 | 09:30 PM
comingup's Avatar
Did you check the fuse
Old Jan 10, 2012 | 06:35 PM
Ricksi30's Avatar
If it is the fuse I'll be shocked. I doubt it would have slipped my mind at the time but I'll check again. Thanks!
Old Feb 25, 2012 | 12:29 AM
KBCobra's Avatar
It is very unlikely for both of them to go out at the same time. If you had electrical done around the same time they stopped working, there is a high possibility something got shorted out and blew a fuse.
Mar 12, 2020 12:06 AM
The Frye
Feb 3, 2019 08:34 AM
markevans999
Sep 10, 2015 04:29 PM
ef9
Sep 5, 2015 11:18 PM
maximusrising
Sep 4, 2015 06:31 PM
