Replaced Bose Sound is not good
Old Apr 24, 2012 | 06:39 PM
Lt.Tealc's Avatar
Replaced Bose Sound is not good fixed
Yaw.... Hello
Just replaced my 2002 bose Headunit with Kenwood DPX308U
and the sound quality is not good as my bose used to sound.. for starter it,s not loud which is not big deal for me but the Bass is terrible whens u crank it up the sound gets distorted and u can barley hear anything//
which brings to my question is it possible i did not wire it properly
i used Metra 70-7551 harrhess
this is the wires i used
blue/white = amp on
orange= illumination=
2 black= ground
blue = antenna
4 Rca 1 for each speaker
did i mess some wiring i don't recall seeing sub woofer wire
it took me 4 hour to install
here are some pictures
do u guys think i will get better quallity with this harrness
PAC ROEMNIS2
Old Apr 24, 2012 | 07:32 PM
DAlastDON's Avatar
On the 6th gen that there are two different harness's. One that supplies the bose amp with a pre-amp signal and on that supplies a speaker level signal. I have read that the speaker level performs much better with the bose system then the pre-amp. The head unit you selected is only putting out 2v on the pre-amp outputs. The factory unit put out at least double that and the bose amp does not have a gain adjustment as aftermarket amps do.
I would just cut the RCA ends off and splice them into the speaker level outputs on the receiver. But let some one else chime in with first hand experience with the 5th gen before you do that or order another harness.
Old Apr 24, 2012 | 10:50 PM
Lt.Tealc's Avatar
this might work
the 5th Gen have two different adapters as well, on the sticky topic it recommended the harness i have+ crutch field shipped it with the head unit
thank you for your input it might be just i was looking for... one u say slice just the rca u mean keep the existing harrness i already connected and just connect the RCA to the new one or rewire everything
Old Apr 25, 2012 | 05:44 AM
installer's Avatar
what you need to do is get the other harness slicing int the rcas isnt the right way being that the wires inside the rcas are 24 guage if you get the othe harness METRA make it its a 70-7550 it has speaker wires on it that are about 18-16 guage will be better for the performance of the radio
Old Apr 25, 2012 | 06:38 AM
UGAd13's Avatar
Looks like it's only running 2V pre-amp outs... You need a HU with at least 4V for the 70-7551 to work properly.
Read through this and you'll see what others are using:
http://forums.maxima.org/audio-elect...thread-21.html
Old Apr 25, 2012 | 11:10 AM
Lt.Tealc's Avatar
thanks it turns out i need Line Out Converter, thanks to that thread
Old Apr 25, 2012 | 11:18 PM
Pearl96Max's Avatar
I tend to get a bit irritable
No convertor. Either get a 70-7550 or just snip of the male ends of the RCAs from the 7551 and connect accordingly to the speaker wires on the HU.
Old Apr 26, 2012 | 12:42 AM
Lt.Tealc's Avatar
i am gonna snip the RCA's and plug them to the head unit i am gonna order the PAC harness incase of this didn't work
did u had a similar issue . thanks BTW
Old Apr 26, 2012 | 05:47 AM
installer's Avatar
your going to do it the ghetto way go out and spend the $15 for the metra 70-7550 dont cut the rca's trust me the wires are to thin and can effect the sound qualiry you dont need to order the pac harness either have used it before and always had better luck with the 7550
take the advice im a vet installer 15 years doing this
Old Apr 27, 2012 | 06:06 PM
Lt.Tealc's Avatar
BOOM BOOm u are awesome
i don't know how to thank you i purchased the 7550 and it sounds fabulous it,s loud to the point that if i leave it on for a while i might be damaging the speaker..
i am experience some static when nothing is playing but that,s no issue , i thank you again you are awesome,:e ek::eek
Old Apr 27, 2012 | 06:08 PM
Lt.Tealc's Avatar
thanks to all who helped me through this u got saved lot,s of headache and money *_*
Old Apr 27, 2012 | 06:10 PM
Lt.Tealc's Avatar
Ops "replayed to the wrong thread"
Old Apr 29, 2012 | 08:54 AM
installer's Avatar
your welcome you said it sounds good but a little static where did you ground the radio
Old Apr 29, 2012 | 07:43 PM
Lt.Tealc's Avatar
2bo
this photo is from another max i found online basically they are grounded on those two bolts.. 1 for head unit the other for trip control. i am not expert on grounding but this is the only location the cables did reach hopefully i done it the right way
Old Apr 29, 2012 | 07:47 PM
Pearl96Max's Avatar
Look in and straight down. There is a 10mm to each side that works fine. You only need one ground point.
Old Apr 29, 2012 | 09:19 PM
AscendantMax's Avatar
Pearl96Max sounds like he knows what he's doing
Old Apr 29, 2012 | 09:50 PM
Pearl96Max's Avatar
Nah, I just kinda wing it !
Old Apr 29, 2012 | 11:48 PM
Lt.Tealc's Avatar
i think that,s exactly where i grounded it.. you mean i can ground both cables to same location. one head unit, one trip computer ground.. i really don't feel like taking out the head unit and re grounding now it works little static but acceptable
Old Apr 29, 2012 | 11:50 PM
Lt.Tealc's Avatar
u damn right i researched for weeks cause i refused to pay 150$$ to car toys for installation... yeah Bose was complicated for them.. i am proud of what i have accomplished
Old May 19, 2012 | 10:52 AM
Beancounter Mike's Avatar
Where did you get the 2-din faceplate?
Lt. Tealc,
Where did you get the 2-din faceplate? I can only find 1-din faceplates for a 2002 Maxima. Crutchfields and others say they don't exist but you have clearly found one.
Thanks.
Old May 27, 2012 | 03:14 PM
Lt.Tealc's Avatar
Originally Posted by Beancounter Mike
Lt. Tealc,
Thanks.
sorry for not getting to u quicker.. crutchfield dont sell thoes but it exit there are multiple once this fited perfectley my head unit Good luck
http://www.metraonline.com/part/95-7416G
pls note this is only if you have the bose setup there are other non bose
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
maxinout93
Oct 27, 2015 01:29 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
MikesChevelle
Aug 9, 2015 11:50 AM
follyburr
Aug 7, 2015 09:50 PM
