installation for subwoofer question
Old May 17, 2012 | 07:43 AM
mayweathers82's Avatar
I have an 04 i35 with Bose and wanted to know can I splice the wiring from the trunk (as in the wiring from the Bose sub) to my line out converter instead of taking out my head unit? Of so what wires would o splice? I want to keep my door speakers and so I already know the Bose amp is staying I just wanted to unplug my Bose sub and run a seperate amp and sub. I hope this makes sense I'm typing from my phone at work. Any links on converters recommended and wiring guides are welcome. Thanks in advanced
Old May 17, 2012 | 07:44 AM
**btw
The head unit is stock and I'm not changing it (I like a nice stock look)
Old May 17, 2012 | 09:03 AM
Would this work ? (On mobile site.can't edit post
http://www.autotoys.com/x/product.php?productid=13338
Old May 17, 2012 | 07:59 PM
installer's Avatar
hi if you have the stock sub you can unbolt the amp from the bottom of the sub and use the positive and negative from the amp to the sub they'll be two sets one on each side of the sub just use one and attach the hi lo and then bolt the amp back on
Old May 18, 2012 | 04:12 AM
i have the stock sub, whick wires would i splice? i understand what you are saying but a picture or wiring diagram would be helpful. and would i use a regular hi-lo converter?
Old May 18, 2012 | 05:46 AM
installer's Avatar
yes a regular hi lo would be fine and when you drop the amp off the sub there should be 2 wires going to each side of the sub 1 per voice coil could be red blacl black is negitive or green grey it written on the terminals of the sub what positive and negative are
6spd4dsc
May 9, 2022 12:30 PM
jskirwin
Jun 8, 2016 08:49 AM
starman9215
Aug 11, 2015 06:51 PM
Slamrod
Aug 10, 2015 12:33 PM
papo99
Audio/Video/Electronics
Aug 9, 2015 12:55 PM
