Rear Speakers
Old Jan 7, 2002 | 08:21 PM
Pr1dmx88's Avatar
Rear Speakers
I have a 92 Maxima GXE with the active speakers in the rear. I need to know what speakers size is in the back. and also how to get the grills off the factory speakers so i can get to the screws and see what size they are. I checked crutchfield and in some magazines it says 6x9 bottom mounts and other magazines say its 6"3/4". whats the real deal? and how do i get those grills off.
Old Jan 7, 2002 | 10:24 PM
95emeraldgxe's Avatar
i wood trust crutchfield, but just take a look at the grille......if its oval......then its 6x 9 otherwise they the 6.75's
Old Jan 8, 2002 | 11:58 AM
Pr1dmx88's Avatar
I would trust crutchfield but there giving me to different answers some say 6x9 some say 6.75". and the grills are like a square so it can be both. if you could in detail tell me how to take them off i would greatly appreciate it. thanks for the post anways.
Old Jan 9, 2002 | 04:50 PM
Pit5Bull's Avatar
OK, Sparky, here's the deal…
The stock openings back there are for 6.5" ovals, I believe. I have a pair of Kenwood 6x9's mounted with adapters back there. In order to remove the Bose amp assemblies, you'll have to remove your back seat, then your rear deck in order to be able to remove the nuts that are holding it up back there (I think there were 4 bolts back there, but I'm not sure). It's a pain in the a$$ if you're doing this by yourself, but once it's done, you'll be able to do it anytime you want - but it'll STILL be a pain in the a$$!!! Once you do that, the assemblies should fall off the rear deck, and you'll be glad you did it, too. My 6x9s were attached to the bottom of the assemblies when I bought my car, and they sounded like **** (I thought the speaker was blown).
The grilles are attached to the rear deck, so anything you put back there will be covered up pretty well. I'm considering going with some bottom-mounted 6.75" speakers back there because I don't like the way the 6x9s are attached to the rear deck, plus I think that my adapters are damaged. Anyway, I hope that helps!
peace2u
Old Jan 9, 2002 | 05:57 PM
Maxima NutBag's Avatar
I have an 89 GXE, and when I put Pioneer TS-601 6x9"s in the back, the audio people where I had it done had to cut the back deck. Got to keep the original rear grilles though. The front speakers are 4x10" Pioneers.
BTW, anybody know how to eliminate rear deck rattle effectively?
Old Jan 9, 2002 | 06:19 PM
Pr1dmx88's Avatar
Re: OK, Sparky, here's the deal…
peace2u
So I shouldnt get the 6x9's? and the 6.5" and the 6.75" drop right in with no mods. yeah i know removing that back seat is a pain i had to do it once. Thanks for the info. peace
Old Jan 9, 2002 | 06:22 PM
Pr1dmx88's Avatar
peace2u
also i went to best Buy and they said that i would have to rewire my rear speakers because they are the "active speakers" when i got my new head unit. is that true? and is there anything else i can do? and what does active speaker meen? just wondering if you know thanks for the help.
Peace
Old Jan 10, 2002 | 11:37 AM
Pit5Bull's Avatar
Pr1dmx88
If you haven't already purchased the 6x9's, and if you don't want to do any major mods to the rear deck or use adapters in order to install them, then I suggest going with the largest rounds that you can fit back there comfortably - you may be able to do better than 6.5", I'm just not all that sure. The only issue would be if you're concerned about how much the rear speakers can handle, because 6x9's generally are built to handle more wattage than their round coaxial brothers do.
You don't want to go breaking your bank account for rear speakers anyway. Most audio guys will tell you to concentrate your time, energy and cash allocations to your front soundstage - that's where you - the driver and owner - reside, and you should have "the best seat in the house" as far as your sounds go. The rear stage is just for filling the dead space in the back window area anyway. Your soundstage is supposed to resemble a seat at a concert, where all the action and the sound is coming from.
BTW - I have NO idea of what an 'Active Speaker' is. I know that's what the grille on a non-Bose stock system reads, but I don't know what's under there
Good luck with your install and your choices - sometimes I think there's too much to choose from!
peace2u
matts95max
Apr 23, 2025 10:44 AM
9aj9
Apr 5, 2020 12:11 AM
bbsitum
Sep 11, 2015 04:55 PM
A32goldylocks
Sep 2, 2015 06:39 AM
