General Wiring Question......
Old Jan 21, 2002 | 11:05 PM
DMAN11's Avatar
Hey guys,
I am replacing my front speakers with some new Boston Acoustic Components. My question is about the wiring.... When you guys replaced your factory speakers, did you use the factory wires for the new speakers you put in, or did you run all new wires?? I was told that I might need to run new wires to the new tweets cause there may be a built in filter on the factory ones,,,,anybody have any idea on this?? I have a 2K1 Max with upgraded system, not BOSE though. Thanks for any input......DMAN
Old Jan 22, 2002 | 04:04 PM
DMAN11's Avatar
BUMP!
COME ON GUYS,,,,I KNOW PLENTY OF YOU HAVE CHANGED OUT SPEAKERS.....
HOW BOUT IT MAXIMADAVE, JMAX, MATT93, MAXSTILLEN,,,,ANYBODY?????
Old Jan 22, 2002 | 05:12 PM
maximadave's Avatar
detailerdaveb@gmail.com
Re: General Wiring Question......
Originally posted by DMAN11
Hey guys,
If you are running deck power only you will be fine with the factory wiring. If you plan on running an amp, upgrade the speaker wire.
Maximadave
Old Jan 22, 2002 | 09:03 PM
jmax
Sorry, I haven't run speakers off of a headunits amp in over ten years. Actually, never. I have never owned a headunit with built in amp. So I always run new speaker wire. If you are running components you will need new wiring unless you trace the factory wiring into the car or wherever your crossovers are mounted, and connect the factory wire to your crossovers.
aw11power
Oct 10, 2021 04:57 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
