Install of LEDS cause Electrical/light problems
Old Sep 8, 2014 | 06:08 PM
Itz Shak's Avatar
After attempting to install led light in dome light, my trunk light stopped working... Me being careless about that specific light, I continued to put blue led bulbs in all four of my side markers and this caused the following problems:
Keyless Remote doesn't work.
Dome light doesn't work unless key is in and doors are closed.
Trunk light still inactive.
I can't even use the lock/unlock button unless the key is in "on".
Now i figured that it must be too much energy from the led lights? Is there a way i can keep the lights and fix these issues?
Old Sep 8, 2014 | 06:11 PM
The_Fixer's Avatar
You shorted something and blew a fuse
Old Sep 8, 2014 | 09:16 PM
bumpypickle's Avatar
Did you remove the negative cable from your battery before doing electrical work? Were they plug n play?
Old Sep 9, 2014 | 02:48 AM
Itz Shak's Avatar
Sheesh, I'll go ahead and replace the fuse..
No, I didn't even think to remove the negative battery.. and yes they were plug and play
Old Sep 9, 2014 | 04:13 AM
The_Fixer's Avatar
you know just because they claim plug and play dont mean they are.Let me give you some free learning,incandesent bulbs have a different resistance then a LED second a LED bulb draw less current have lower voltage requirements and act differently in each of your situations.so what this means is your car is not seeing the correct load on lighting system due to them being LED's so its acting weird and i bet you have ebay etc. leds dont you and that makes it worse.look up a member here named Amerikanner he is a led expert and may be able to point you in the right direction.I could but you used blue leds in your side markers and thats just a HUGE NO NO in my book.So good luck and listen to what the people here tell you as we have been thru the issues before and know how to fix them.
Old Sep 9, 2014 | 12:05 PM
Itz Shak's Avatar
Thanks alot mate. Read your first post and that fixed the problem, it was a lamp fuse under the dash. When you say issues, it wouldn't be so bad that a replacement of a fuse couldn't fix it would it? Thanks again
Old Sep 9, 2014 | 12:23 PM
MaximaDrvr's Avatar
Like being arrested for having blue lights on your vehicle? We can't fix that.
Old Sep 9, 2014 | 02:12 PM
Itz Shak's Avatar
For blue side markers?
Old Sep 9, 2014 | 06:50 PM
MaximaDrvr's Avatar
As far as I know, every state in the south east has laws making illegal for any blue lights on a vehicle. I don't know where you are, but generally blue lights on a vehicle just make you a dbag...
Old Sep 9, 2014 | 07:33 PM
ac max 92's Avatar
Just to add to that here in Canada they're illigal too. It's o.k for your interior but in your marker lights etc. is a no no. Only emergency response vehicles can have blue lights. Police, Ambulance etc. A bluish tint to your HID headlights is one thing but putting LED blue lights anywhere on the exterior of the vehicle. Not good. That's just asking to get pulled over.
Lakersallday24
Nov 7, 2024 07:31 PM
Cotozic
Jun 28, 2017 08:01 PM
Team STILLEN
Aug 10, 2015 04:29 PM
kirkhilles
Aug 8, 2015 10:53 AM
