Have bose stereo, want cleaner sound...... PLEASE HELP !!!
Old Jan 25, 2002 | 11:30 PM
bhaske1's Avatar
The stock 98 SE bose stereo in my car sounds decent, until it is turned up. I would like to add a subwoofer in the trunk, but keep the stock mids/tweets. Can I cut the low bass from the stock speakers and keep the mid bass from the stock speakers, and just get low bass from a sub? How do I add an amplifier to the stock system, just for the sub?
Old Jan 26, 2002 | 01:14 PM
adamlacey's Avatar
Get a crossover, u might be do a little work to find the right wires, but that will do the trick...
Old Jan 27, 2002 | 05:47 PM
ny96max's Avatar
Re: Have bose stereo, want cleaner sound...... PLEASE HELP !!!
you will need a high/low converter($40) and 8 gauge amp wiring kit ($50-60). Install is fairly easy. Just find both REAR speaker leads coming off the back of the bose headunit. It would be easier if you has a Nissan 95+ wiring harness as a reference. All you have to do is plug in the new harness to the existing harness and follow back the green and purple wires into the existing harness(one that plugs into Bose) just tap into those wires and your set! Run you rpower wire and rca's(opposite sides of course) and your good.
Ant
Old Jan 27, 2002 | 08:39 PM
bhaske1's Avatar
Re: Re: Have bose stereo, want cleaner sound...... PLEASE HELP !!!
Ant
Ok so Im not a stereo guy, BUT deal with me. Where do I buy this convertor from? I understand the "8 guage amp wiring kit" includes RCA's for the amp to plug in. So just look for the green and purple wires and I don't need to mess with the harness that is pluged into the back of the headunit!?! How do I then cut the low end and have only mid bass come from the factory bose speakers? Oh, by the way, how is the proper way to remove the head unit. Sorry to be such a pain.
leatherneck
Sep 30, 2015 09:16 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
