2k2 speaker install
Old Feb 2, 2002 | 01:05 PM
rossg's Avatar
2k2 speaker install
For anyone who has installed 6.5's in the front and rear doors on a 2k2- Did you have to use/make any type of a bracket or spacer, or will aftermarket 6.5's drop right into the stock locations ?????
Old Feb 2, 2002 | 10:25 PM
95emeraldgxe's Avatar
i never did it b4........but i dout that u will need nethng extra.....btw......i think 6.75's fit better
Old Feb 2, 2002 | 11:37 PM
ny96max's Avatar
yeah, the majority of Max's from 95-2000 have oversized 6.5" speakers front and rear. You can buy adapter rings at any local stereo shop for cheap, $20 a pair. I would just go to www.crutchfield.com they always have them instock and have the best price for them.
Ant
Old Feb 3, 2002 | 06:32 AM
soundmike's Avatar
Very sound, Mike
You'll need the brackets. There's 3 ways you can go about it: (P.S. I have 6.5's btw)
1) Use your existing speakers, check out the FAQ's/How-to's on how to modify it so you basically take the old speakers out yet keep the bracket/basket intact. You then attach your aftermarket's on it.
2) Purchase the same brackets (w/o the speakers) from your local Nissan dealer. They run approximately $32 for all four.
3) Buy the brackets on Crutchfield or your local car audio installation shop. They're not as flush as the first two but it does it's job well plus it's cheaper (i got mine for $11 for all four).
- Mike
Old Feb 3, 2002 | 11:36 AM
skyjay617's Avatar
cut the speaker off and use the factory bracket
go check here , this is from the how to's in 5th gen forum...just cut the speaker out of ur factory bracket....then use the factory bracket, then drill holes.....it fits perfectly if u r doing the "how to's" steps...
hope it helps
Old Feb 4, 2002 | 07:30 PM
rossg's Avatar
Thanks Guys !!
9aj9
Apr 5, 2020 12:11 AM
Mar 12, 2020 12:06 AM
popdedop
Sep 11, 2015 11:17 AM
videomano
Sep 8, 2015 03:28 PM
