Arranging speakers - component systems
Old Feb 8, 2002 | 08:43 AM
CoolMax's Avatar
is invisible
In a component system, we know there is a tweeter and a woofer. Obviously the tweeter goes up on the front door, sail panel, etc.
But what about the woofer? Does that go in the front door? If so, what about midrange - do you count on your rear speakers for that?
Is the proper arrangement more like - tweeter up front, midrange in the front doors, and woofers in the back?
Or tweeter, woofer, 2-way/midrange?
What does throwing in a subwoofer do to this setup?
Sorry for the number of questions, but I hope someoen can clear this up for me. Thanks.
Old Feb 8, 2002 | 09:15 AM
kingston's Avatar
are you going with 3 speaker component or 2 speaker component.
either way in any case, if you have some money to spend, i would recommend getting kick panels. It will give you the best sound staging.
If you go with that, midrange and tweeter can go on the kickpanel. If you go with 3 speaker component, put the woofer in the door. There's your three speaker set up right there.
Old Feb 8, 2002 | 09:43 AM
CoolMax's Avatar
is invisible
Haven't done it yet. But when I do, I'll probably go the 2 speaker route.
And if I don't get kick panels?
Old Feb 8, 2002 | 04:12 PM
Micah95GLE's Avatar
Any set of separates will play all frequencies (including midrange) from about 80Hz - 20,000Hz. Why would anybody make a set of speakers that leaves out the most important bandwidth?
Old Feb 8, 2002 | 04:51 PM
max'n out's Avatar
Idealy (competer mind) all speakers go out in front of you using the fewest amount of speakers possible. This to properly produce a sound stage by way of the way it's done in a concert hall. A car being smaller and so many being so diff. it can be acomplished in many many different ways.
Old Feb 8, 2002 | 09:32 PM
CoolMax's Avatar
is invisible
Well, I guess I should have known that - or read more closely.
Since they are separates I assumed they were more focused on a specific range, with the tweeters handling the highs and the woofers handling the lows (obviously). Using that reasoning, I was curious as to what covered the apparantly lacking midrange.
If separates (tweeter, woofer) play all frequencies then what is the point? Why shouldn't I buy normal 2- or 3-ways? In Crutchfield, why are midranges sold in the same section as the component systems?
Old Feb 8, 2002 | 09:34 PM
max'n out's Avatar
You got the idea basically. Midbass is about 80-300 midrange 300-3000 highs 3k-20k. So if you have a basic 3 way system mid tweet and sub, the mid plays the midbass and midrange. Where as a 4 way there is a mid for each.
Old Feb 10, 2002 | 10:38 PM
CanuckAMP's Avatar
They are sold in the same sections due to their frequency range setups. Midbass/midrange can be covered by a single driver or a pair of different drivers provided they have a crossover between them.
magiconthetire
Oct 26, 2015 09:03 PM
RealityCheck
Oct 2, 2015 06:34 PM
MichMaxFan
Sep 30, 2015 09:18 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
