02 max se 3.5 drivers window
Old Oct 16, 2025 | 06:40 AM
denise1968's Avatar
Hello,
my drivers window will not go up or down.
Previous to the window not working at all,
it would go up very slowly and it made noise
like it was almost rubbing on Something.
anything helpful you can throw my way would
be appreciated
thank you
Old Oct 16, 2025 | 08:27 AM
RA030726's Avatar
I'm nutty for Nissans
Something similar happened to a family members 02. One window stopped working and while I had it all apart it started working again. Never did figure it out.
Being noisy, it may need a regular and or motor. You should test the electrical parts first. Same for your sunroof issue. Inspect the connections for corrosion or damage. Use a multi meter to see if the motor is getting power when the switch is operated. If no power check the switch.
Old Oct 17, 2025 | 02:13 AM
denise1968's Avatar
There is zero power going to the sunroof buttons😢
Old Oct 17, 2025 | 06:48 AM
RA030726's Avatar
https://www.nicoclub.com/FSM/Maxima/...L.pdf?embedded
The wiring diagrams for both the windows and sunroof are in there.
Old Oct 19, 2025 | 05:43 AM
denise1968's Avatar
Great thank you so much
CauzinDrama
May 25, 2013 05:03 AM
MrGone
May 3, 2004 06:27 AM
tyrotrader
Nov 12, 2002 07:29 AM
