Speaker Wire Size....
Old Feb 9, 2002 | 10:19 PM
DMAN11's Avatar
Hey guys,
I am upgrading all my speakers, and putting an amp to them. I am planning to run some new wire to them instead of the factory wire... Do you think I can run some 18g or 16g wire?? The Boston Acoustics speakers I bought have 18g wire with them. Do you think that would do, or should I go with bigger stuff like 16g?? What do you guys think??
,,,AND,,,
I am running 2 amps. I have an 8g wiring kit for each one. Do you think it will be OK to run 1- 8g power wire for each as opposed to running 1- 4g wire to a distibution block and then the 8g to the amps?? I don't think it will matter either way, but what do you guys think?????Thanks guys,,,,DMAN
Old Feb 9, 2002 | 10:25 PM
chinaonnitrous1's Avatar
I would just run 16 ga if you can, its not much of a difference but its worth it in the long run. You will have a much cleaner and trick install if you run 1 4ga cable from the battery to a distriboution block. I looks better..and less wire to stuff under the carpet.
Old Feb 10, 2002 | 09:58 PM
StaindMaxima's Avatar
Depends on the wattage that you are pushing to your speakers. I ran 12awg to mine.
2 8awg wires is fine, but not as clean as the last guy said...1 4awg looks much better.
Old Feb 10, 2002 | 10:01 PM
CanuckAMP's Avatar
Not really. Depends more on the length of run. For most applications 16G is fine anything larger is overkill.
Now that being said I do have some overkill in my system with 12G wires running to my midbass drivers in the doors.
Old Feb 10, 2002 | 10:25 PM
True, it does have much to do with the length, but also the wattage. And yes 16awg would prob. be fine, I agree. I have a pretty beefy 4ch. amp though and felt that noise shielded 12awg would be better for my particular application.
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
