Double DIN Radio Recommendation
Old Jan 15, 2026 | 09:32 AM
I35GEEK's Avatar
My Bose HU has finally given out after 23 years in my 2003 Infiniti I35. I am looking for a Double DIN size HU to replace the dead Bose one. I don't want anything fancy like touch screen. I only use the bluetooth to play spotify off my iphone. I want a budget HU that is of decent quality. After doing some research, I know Boss is cheap and so is their quality.
So far, I've spoken to Crutchfield. They receommend the Kenwood DPX395MBT for $169
https://www.crutchfield.com/p_113DPX...DPX395MBT.html
I've searched on Amazon. and found the JVC KW-SX88BT for $129
Amazon.com: JVC KW-SX88BT Bluetooth Double Din Digital Media Car Stereo with Shallow Chassis, Variable Color Dsplay, Front USB and Aux, Powerful Amplifier, AM/FM Radio, Perfect OEM Replacement for Your Vehicle : Electronics Amazon.com: JVC KW-SX88BT Bluetooth Double Din Digital Media Car Stereo with Shallow Chassis, Variable Color Dsplay, Front USB and Aux, Powerful Amplifier, AM/FM Radio, Perfect OEM Replacement for Your Vehicle : Electronics
What other options should I consider? Which one would you pick?
Old Jan 15, 2026 | 03:09 PM
RA030726's Avatar
I'm nutty for Nissans
Are you still trying to keep the bose amp and speakers? If so, you'll want 2 pairs of pre outs. That JVC only has one.
Old Jan 16, 2026 | 05:11 AM
I35GEEK's Avatar
I am going to upgrade in 2 phases. First, I am just going to replace my Bose head unit with aftermarket and keep my Bose amp and speakers. If it sounds OK, then I am done. If it sounds horrible, then I am going to replace the Bose speakers with aftermarket. I am then going to use the amp included in the aftermarket DIN radio. Given the age of my car, I am trying to keep it as simple and cheap as possible.
Why do I need 2 pre outs if I want to keep my Bose Amp & speakers?
Old Jan 16, 2026 | 05:27 AM
Prophecy99's Avatar
i have a complete Blue Tooth Head Unit set up with all conversion from Bose and utlitize Bose Amps. i took it out of my 2002 before it went to the junk yard. i
doe the I35 have the same trim panel I have that too? I can DM you some pics and offer you a great deal. I got it all through Crutchfield.
Alpine UTE-73BT
Old Jan 16, 2026 | 05:31 AM
RA030726's Avatar
If you use the speaker outputs then you will need to buy a line out converter to drop the speaker level to pre out level. I had Bose in my old 98. I connected a new HU with 2 different converters, one was very noisy. The other just didn't seem right or it broke. Instead, I used the RCA pre outs and made my own harness to feed the Bose amps. What I made looks just like the Metra 70-7551. Also, if you end up getting rid of the Bose amp and speakers you won't need the converter so that is a waste of money.
Old Jan 16, 2026 | 05:41 AM
Prophecy99's Avatar
PM sent ! i have the RCA pre output parts Jsutter is mentioning, full kit.
i can't believe I didn't upgrade my Bose HU earlier, swaping to a new head unit was the best ! I honestly miss it , compared to my new cars stock bose hahahaa
Old Jan 27, 2026 | 04:15 AM
I35GEEK's Avatar
Did you plug the 2 pairs of RCA's into 2 pairs of pre outs from the new HU? How does it sound? Now I understand your earlier message: "re you still trying to keep the bose amp and speakers? If so, you'll want 2 pairs of pre outs. That JVC only has one."
Old Jan 27, 2026 | 07:22 AM
RA030726's Avatar
Yes, the bose amps were connected to the HU using both pairs of preouts.
Here's something I said way back on 2009 about it.
"Ive been running an Alpine HU, stock Bose amps/speakers, and a separate amp and sub for years. I have wired the Bose speakers a few different ways. The best sounding and most reliable was to use the RCA pre outs, sending the low level signal to the Bose amps. I had a converter but it sounded like *** no matter how much I adjusted the trim pots."
rellrealist
Feb 12, 2015 12:03 AM
Max_Gator
Aug 25, 2008 02:34 PM
ScholaR?
Feb 5, 2006 02:33 PM
usmcbigguns
Aug 2, 2004 01:33 PM
maxdrvr847
Aug 15, 2003 09:57 AM
