Infinity Basslink
Old Feb 21, 2002 | 08:47 AM
Miguel97GLE's Avatar
Infinity Basslink
Anyone have any experience with this product? How would you rate it's performance vs a decent single sub/amp combo? Thanks
Miguel
Old Feb 21, 2002 | 10:40 AM
Re: Infinity Basslink
I just thought of a few more questions. Has anyone add a Basslink to a stock Bose system? What all was involved in the install? Were any special parts needed? Thanks
Miguel
Old Feb 21, 2002 | 02:52 PM
Maxstilln's Avatar
Re: Re: Infinity Basslink
Miguel
The Basslink is a great product, you should check out the new basslink "X" its clear, looks cool Keep in mind its not something that is going to shake the car but if your looking to add some bass it does that quite well. There is also an optional level control **** you can buy for about $30 so you can turn the sub up and down from inside the cabin. As for the install its really easy, all it requires is power, ground and signal. It has a smart turn on feature so it will turn itself on and off with out a remote wire when you use the high level inputs. To intergrade it with your Bose all you would need to do is tap into the rear speakers wires and run them into the high level input on the Basslink. Should take you about an hour if you have done audio stuff before.
Old Feb 21, 2002 | 03:44 PM
Cisco's Avatar
I used this in my maxima for 1 week and returned it because the bass was not sloppy and not controlled. I'd suggest a sub/amp combo.
GC
Miguel
Old Feb 21, 2002 | 08:12 PM
ne max's Avatar
Re: Re: Re: Infinity Basslink
GC
how loud did you play it till it got sloppy? i'm also considering basslink but don't plan on blasting it really loud. it has a class d amplifier which ought to be decent
Old Feb 22, 2002 | 12:22 AM
soundmike's Avatar
Very sound, Mike
Funny that you ask. I asked about the same thing a couple of months ago.
Anyway, i decided to go for it because i just want a good SQ system that doesn't eat up my entire trunk. I got it used for $160 from a guy at the Sounddomain forum. Will be installing it this weekend.
When i auditioned this at Cartoys i didn't like how it sounded but then again it was just placed on the shelf while the reference system was a set of 12" subs in custom enclosures which, obviously, sounded awesome.
I noted that the Basslink was made to sound good inside the car so obviously it would sound like crap on the shelf. It's just like making a sealed sub work in a free air environment.
For a 200w (RMS) amp, a 10" sub, a 10" passive radiator all for such a price you really can't go wrong with it. Granted you won't win any SPL wars but like i said that's not what i'm out to accomplish.
I'll let you know how it goes.
Old Feb 22, 2002 | 05:12 AM
ne max's Avatar
thanks
litch
123
Jan 4, 2024 07:01 PM
9aj9
Apr 5, 2020 12:11 AM
trsandrew
Apr 8, 2016 06:45 PM
RinconI30
Nov 10, 2015 10:55 PM
trsandrew
Oct 25, 2015 02:47 PM
