will one ppi 1200.1 be enough to power 3 kicker L7's??
Old Mar 10, 2002 | 03:15 PM
khrfadz's Avatar
will the 1200.1 ppi amp be enough to power 3 12 inch solobarics dvc 4-ohm L7's??? if not then will 2 be enough??? any suggestions on amps is welcome so i can get the best power to those subs.
Old Mar 10, 2002 | 08:22 PM
MaxedOut2g's Avatar
Re: will one ppi 1200.1 be enough to power 3 kicker L7's??
how many watts is the 1200.1? this guy i sort of know is running 2 PPI 600w amps, dont know model #, on 2-12" L7's and its freakn loud...i can here him rolling up from like 1/2 way into my school..and when you stand next to his car, its like the ground is shaking...my goal is to have those 2 amps powering my subs, cuz its plain kick assssss
atw
Old Mar 10, 2002 | 09:44 PM
puremax's Avatar
nope not enough power
Old Mar 10, 2002 | 10:51 PM
OgreDave's Avatar
3 dvc 4ohms? How do you plan on wiring that? You wouldnt even be able to get 1ohm outta it.. you might be better off with 2 DVC4 for final load of 1ohm. (which is what most class D's put max power out at)
(note i have no idea where ppi 1200.1 puts out max power, tho im guessin 1200w at 1ohm from its model #)
Old Mar 11, 2002 | 09:10 AM
khrfadz's Avatar
im gunna run them parallel so i can get a 2-ohm load. i dont think those subs can handle a 1-ohm load
Old Mar 11, 2002 | 09:15 AM
maximadave's Avatar
detailerdaveb@gmail.com
Old Mar 11, 2002 | 09:28 AM
khrfadz's Avatar
Originally posted by maximadave
please correct me if im wrong i dont want to mess up the subs. hey dave, do u think i should get that ppi amp??ur suggestin is needed cuz im going tommorrow to buy it
Old Mar 11, 2002 | 01:26 PM
OgreDave's Avatar
subs dont handle loads. subs PRESENT loads to amps. its amps that can or cant handle loads.
3dvc4 in parallel would net you like a .66ohm load. i dont remember how to calculate it, i just remember the standards like 3 dvc6's, or 2 dvc 2/4 ohms..
sub#1 4-4 =2
sub#2 4-4 =2
sub#3 4-4 =2
they would become 2 ohms EACH in parallel. If you parallel 2 of those subs, you'd have a final of 1ohm. The third should drop you to either .5 or .66. Doesnt matter really, cuz your amp probably cant handle it.
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
