IMPORTS~list
Old Mar 28, 2002 | 09:57 AM
sportscarboy715's Avatar
IMPORTS~list
List your IMPORT and your mods here, since we cant list everything, this is so everyone can see wut your running. If you want to list 1/4 mile time or 0-60 do it...
C7W1O5
Old Mar 28, 2002 | 10:05 AM
Re: IMPORTS~list
C7W1O5
I have a '99' GXE in super black, with stillen exhaust, monsta filter, custom straight air filter pipe (where the sensors in the box used to be for the air filter ), Koenig Rims, Tokico shocks, eibach springs, it is lowered 1.7" and has a stillen strut and sway bar in front and back. the baffles were removed, The engine is chromed clean. Bosch Platinum 2 tip plugs. The interior is fully original, but in place of the stock tape player there is a Pioneer Double Din Head Unit (4V), Polk DB Speakers and Polk MOMOs in back, Monster 2awg from the battery to the amp and 4 awg to the sub and 6 awg to the speakers from the amp to the speakers. In the back there is a 12" MTX Blue Thunder Competition Subwoofer. The Amp is Ferro-Liquid Cooled and so are the tweeters, everything looks stock and its a sleep, 0-60mph is 6.4s and 1/4 is sstimated at 15.1s but that was on a straight away on a back road (yea you all know youve done, :smile: haha. List On..
Old Mar 28, 2002 | 01:01 PM
max'n out's Avatar
Amps- (3) Zapco C2k 2.0
Processors- (3) Zapco Eq 30 – Sl- Equalizers
Zapco Slx-4- Crossover
Zapco Da2-sl - D/A converter
Zapco Vfm-Sl –Balanced line transmitter
Zapco Psi- Power supply
Head unit- Nakamichi Mb100- 6 disk in dash changer
Speakers/Subs- Mb Quart QSD 6.5 components
Mb Quart 10“ Premium
Power- SVR Battery
Alumapro’s “The Cap” 15 Farad capacitor
Miscellaneous- Viper alarm
Zapco Symbilink Cables
Dakota Digital Gauges
Front and rear Clear side markers
Engine-
Vortech V2-SQ (super quiet) Supercharger
3.25 pulley (10psi)
Custom Intercooler and Pipes
Greddy Type- S Compressor Bypass Valve
Custom Exhaust w/ high flow cat & Resonator
Apex-I Super AFC
NGK spark Plugs- 2 steps Colder
Vortech 8:1 FMU
Wheels & Tires
19”X 8.5” Volk Racing AV3
Yokohama AVS Sport 245-35-19 Z Rated
Brakes
Stillen/AP Racing- Front
4 Piston Calipers
13” Drilled and slotted Rotors
Stainless Steel Brake lines
Pads
Rear
Drilled Rotors
S.S. Brake lines
Pads
Suspension
Cattman Coilovers – Generation 2
Stillen Front Strut tower Bar
Stillen Rear Sway Bar
Transmission-
Upgraded and blueprinted transaxle for extreme duty application, which includes durability upgrades, balancing of internal components, and valve body modification.
Custom axle
Custom Transaxle housing
Heavy-duty differential
Torrington bearing set
Teflon Bushing kit
Kolene direct steel
Ceramic direct clutch pads
Kevlar Bands
Billet clutch drum (high Drum)
Race sleeves
Tapered roller bearings
Ring and Pinion Gear set
Case harden torque converter input hub and fluid balanced the converter
Hardened input shaft
A Custom form of Posy- traction
New gear ratio
Grade A bolts
Custom Fluid
Pressure Switch
Old Mar 28, 2002 | 05:49 PM
ZIPPIN's Avatar
Mauja He Mauja
Power- SVR Battery
Engine-
3.25 pulley (10psi)
Apex-I Super AFC
Vortech 8:1 FMU
Wheels & Tires
Brakes
4 Piston Calipers
Pads
Rear
Drilled Rotors
S.S. Brake lines
Pads
Suspension
Transmission-
Custom axle
Teflon Bushing kit
Kolene direct steel
Kevlar Bands
Race sleeves
New gear ratio
Grade A bolts
Custom Fluid
Pressure Switch
Old Mar 28, 2002 | 10:58 PM
Matt93SE's Avatar
STFU n00b!
this is the audio and electronics forum, not the post ***** forum. If it's not audio/video/electronics related, please leave it in the general or off-topic forums.
MaxLvr21
Oct 17, 2015 12:11 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
REDinLV
Sep 28, 2015 12:31 AM
