2000 Maxima Aftermkt. HU
Old Apr 30, 2002 | 09:35 PM
WillLin's Avatar
Hi,
I recently bought a 2000 Maxima w/ Bose sound system.
I was wondering if I need to replace the whole system (headunit + speakers) if I wanted to install an aftermarket CD Receiver + CD Changer.
If there's adapters available for Bose, how much would they be?
Thanks.
- W.L.
Old May 1, 2002 | 10:45 AM
Tony Fernandes's Avatar
Re: 2000 Maxima Aftermkt. HU
Originally posted by WillLin
Hi,
Thanks.
- W.L.
Bose makes it extremely difficult to add any aftermarket stuff. Trust me. It is actually easier (and it's still not "easy") to replace EVERYTHING...HU, wiring, your own amps, speakers, etc. All of the aftermarket wiring harnesses I looked at were not 100% compatible and left too much for guesswork.
Check out my thread I started:
http://forums.maxima.org/showthread....hreadid=113126
Tony
Old May 1, 2002 | 08:09 PM
ny96max's Avatar
Ive been installing for 5yrs now and do this for newer max's atleast 3-times a week.
If you wanna change out the speakers and deck then you will have to get to each amp and bypass them. All that requires you to do is cut the speaker leads(2-thinner wires out of the 4) goin into the Bose amp and extend them to your new speaker. Then just unplug and cap off(with electrical tape) the main plug goin into the Bose amps.
For the radio all you need is a Metra(2000 and up)dash kit $15.99, a 95+ nissan wiring harness for $15.99 and a Metra Antenna Adapter $10.99.
any questions e-mail me,
Anthony
Old May 1, 2002 | 11:48 PM
Anthony
Well, I've been installing for 16 years and although I've only done one Max (mine) I'm pretty darn good at it. There is only ONE amp, it is mounted to the underside of the rear package shelf. The sub amp is built into the sub itself. Now, the original poster said he just bought a 2K, and it SHOULD be identical to my 2K1 in that respect, no?
Trust me, trust me a hundred times. You will get halfway into "upgrading" the Bose and realize that not only is it easier to replace EVERYTHING, but the SQ you will have when done will be so much worth it.
Tony
Old May 2, 2002 | 06:10 AM
NJMAX2KSE's Avatar
S_H_I_F_T_
Hi,
Thanks.
- W.L.
ive got a 2k and im still running the bose speakers with the facory amp connected to a Sony HU which is also pushing a sony amp for my subs. sound quality is excellent and the only thing that was replaced was the Bose HU
Old May 2, 2002 | 11:04 AM
Re: Re: 2000 Maxima Aftermkt. HU
Hey, Mr. Max. Would you please describe what methods or brands of aftermarket wiring harness(es) you used to attain this?
Tony
Old May 3, 2002 | 10:00 PM
Cisco's Avatar
Re: Re: Re: 2000 Maxima Aftermkt. HU
I 2nd that, I'd be really interested in doing this.
GC
Tony
Old May 19, 2002 | 05:06 PM
MiniRX7's Avatar
If you say taht we can use a 95+ wiring harness for the 2k+ or 2k2,
does that mean that when i take out my 2k2 6disc in dash bose unit, it is plug and play with my moms 99??
Because i think it would be a waste because i am removing the 2k2 as soon as i get my car to get my pioneer installed and i want to install it in to my moms car. She has a 99 MAx SE with BOSE crap..
ED
Old Jun 2, 2002 | 07:11 PM
super32's Avatar
Donating member? what the?!
what happens now?
Anthony
Does the sound quality remain?, assuming that there are no subwoofers connected to the system?
halfpol
Oct 17, 2022 12:16 PM
Nintensity
Aug 13, 2015 05:41 PM
jholley
Aug 11, 2015 09:38 AM
niZ
Aug 7, 2015 10:18 PM
halfpol
Aug 5, 2015 08:24 PM
