wire sharing?
Old May 10, 2002 | 01:52 AM
skyjay617's Avatar
wire sharing?
guys, i am currently have one 500w bridged amp now to push my 600w pioneer woofer, but i am thinking to get another amp to push my front kappa speakers, is it possible to share the power, rmt, and grounding wire with my current amp?? or i still need to hook up in different locations? and for my new amp, since my head unit's sub output already been used by my current amp, how do i connect the RCA cables? share it also? i need advises
thank you all
Old May 10, 2002 | 05:33 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Re: wire sharing?
thank you all
You can share your power wire. You need to use a Distribution block though..1 wire in,multiple out. Depending on what amps you are using and how far they are from the battery will determine the gauge of the wire. If you have 8awg now,you may want to use 4awg to add the amp. Each amp should have its own ground.The remote wire can be added to what you already have in there. As far as your outputs on your radio...You are using the subs out already for the amp you have now correct? then one or both of the other outputs should be used for the second amp. Whenever you share one set of preouts you loss voltage from the source,therefore losing power and quality to your amp. I hope this has been helpful.
--Don
Old May 10, 2002 | 11:11 AM
climaxima's Avatar
That is excactly the way to do it.
I second that!
Old May 10, 2002 | 11:57 AM
skyjay617's Avatar
Re: Re: wire sharing?
--Don
thanks all
Old May 10, 2002 | 12:59 PM
victor's Avatar
about each amp having it's own ground; you can also get a distribution block for the ground.
Old May 10, 2002 | 01:11 PM
Pearl96Max's Avatar
This is true !!!
Old May 11, 2002 | 11:35 AM
skyjay617's Avatar
so how about the RMT wire?? i can also get the distribution block for this too?
Old May 11, 2002 | 04:03 PM
Pearl96Max's Avatar
Nah just a butt connector for that.
Old May 11, 2002 | 07:30 PM
victor's Avatar
yup, that'll work.
mkaresh
Mar 12, 2018 06:48 PM
D Mason
Jun 21, 2016 04:43 AM
leatherneck
Sep 30, 2015 09:16 PM
Marc2theMax
Sep 28, 2015 08:13 AM
