Pc 194
Old May 11, 2002 | 10:45 AM
NJMAX2KSE's Avatar
S_H_I_F_T_
Pc 194
Does anyone know where to purchase this type of bulb
PC194
Old May 11, 2002 | 06:04 PM
PATRICK94SE's Avatar
I would assume that it is a 194 bulb that could be purchased at millions of places. I have no clue what the designation PC is though
Old May 12, 2002 | 04:58 AM
NJMAX2KSE's Avatar
S_H_I_F_T_
not the case PC= Printed Circuit. the bulbs are used behind the dash to illuminate the guages.
Old May 12, 2002 | 06:14 PM
So you are saying you could not just use any 194 bulb behind the guages?
Old May 12, 2002 | 06:42 PM
NJMAX2KSE's Avatar
S_H_I_F_T_
problem is i cant find a base..
The instrument cluster uses a variation of the wedge bulb. They are mounted in a twist lock base that plugs directly into the printed circuit board on the back of the cluster. When sold with the base, these are called PCxxx bulbs, for example a PC194 is basically a 194 bulb that comes soldered into a PC (Printed Circuit) board twist lock base. Older GM cars (around '90 and earlier) used a standard bulb which would plug into a separately available twist lock base, allowing you to easily change the bulb since you could re-use the base. The newer ones have the bulb permanently soldered into the base, so when one burns out you have to try and find the special PCxxx version rather than just replace the bulb in the existing base.
if you are going to change your instrument cluster bulbs to brighter ones, I suggest you just get the separate PC wedge bulb base, then you can use any one of the non-PC standard T3 1/4 wedge base bulbs by just plugging them in.
kingrye
Apr 16, 2002 05:05 PM
MaximaZero
Apr 16, 2002 08:35 AM
02MaXiMa_GLE
24
Mar 29, 2002 08:29 PM
ericdwong
Nov 24, 2001 10:57 PM
