Question about most common rattles
What are the most common rattles associated in maxima's with bass? Especially in the trunk area, because there are rattles in my trunk, but i have no clue where they are, because if i lift the trunk lid, the noises obviously go away.
Also, there is a spot that sounds like someting is rattling in a box down near the left rear tire, just toward the inside quadrant of the vehicle (on the outside obviously). It sounds more like something shaking inside another box, but can't figure out where.
any help would be awesome
thanks
bryan
thanks
bryan
Re: Question about most common rattles
thanks
bryan
thanks
bryan
Yea, i have done the license plat with a dynamat kit.
What about in the trunk lid, there are those 2 fairly large gaps in the metal, if you remove that felt covering (has like 13 black tabs to be pulled out to loosen it), and the holes are big enough to wedge your hand in. That is fine right, doesn't need anything done, because i am not sure if there is anything in there that rattles.
thanks
bryan
thanks
bryan
thanks
bryan
thanks
bryan
Ok, well i have heard of that expanding foam, dynamat, and that Peal And Seal you can buy at Lowes for only $12.50. for 12.5 sq ft.
What if in the future i have to get into that trunk lid?, in the holes i mean.
thanks
bryan
thanks
bryan
thanks
bryan
thanks
bryan
Whats really causing the lid to rattle is the keyhole mechanism thats in there. What I did was I duct taped the whole mechanism down with duct tape (part thats behind keyhole and the rod that connects to the latch. The good thing is that theres no more rattles, bad thing is that you cant use your key to open the trunk anymore since its all taped up. No problem since I never use my key to open my trunk (keyless entry or trunk pop button on the door)
or that peal and seal, right. I got real confused when i got the license plate kit, because it wasn't big enough to cover the whole plate, so i cut it into strips and applied those strips to the sides of my plate rim and the plate itself, but it works just as good. So i used extra pieces for smaller areas in my car.
On the upside I don't think you can hear them from inside the car...
Unclejunebug
Apr 2, 2016 05:42 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
Maximeltman
Sep 28, 2015 07:19 PM
