im hooking up a monitor, which wire should i connect to the power?
Old May 16, 2002 | 12:56 PM
phatmax95's Avatar
I'm gonna connect the power and ground wires from my monitor to the same ones that the cd player uses. Only problem is there is 12V battery wire (yellow) and a 12V ignition/switched wire (red). Should i hook the power wire from the monitor to both or just one of those i just mentioned? Problem is I dont want to accidentally leave the monitor on.. help quick..
Old May 16, 2002 | 04:18 PM
climaxima's Avatar
Your best bet would be to hook it up to the ignition, that way there is no way that you could leave it on.
Old May 17, 2002 | 12:46 PM
phatmax95's Avatar
well, thanks for the input, i did that and it works great now.. 'preciate it
Old May 20, 2002 | 01:12 PM
phatmax95's Avatar
update: when it is off, it flicks on real fast when i am turning the car off. It stays on longer if it was on ON - shorter when it was just ACC. any idea? dont think it will cause i problem.. but i dont know
Old May 21, 2002 | 04:58 PM
96MAXIMAGXE's Avatar
where did you install your tv? lets see a pic
Old May 22, 2002 | 07:19 PM
phatmax95's Avatar
Ill be posting pics of everything installed and ready in just a day or so, look out...
wyobbagy
Jan 3, 2023 12:03 PM
The Frye
Sep 2, 2021 11:03 AM
