Speaker wire colors for 2k2?
Old May 19, 2002 | 08:20 PM
Nathan's Avatar
Today I hooked up my Infinity Kappa Perfect 12.1 with a Rockford Fosgate 2 channel amp to my 2k2 non bose system. I'm using the non bose headunit so I also have a line level converter. The problem I'm having is that when I use the balance control and set it to zero which is the middle, I get no bass. When I set the balance all the way right or all the way left I get a lot of bass.
The Fade function doesn't have an affect on the amount of bass, only the balance function. I'm guessing I mixed up the speaker wires when hooking up the line level converter. Can someone tell me what color the rear speaker wires are? Thanks,
Nathan
Old May 20, 2002 | 08:38 AM
studman's Avatar
2002 Audio Wire Colors
Base Audio System Speaker Wiring Chart:
Back of HU:
Front Driver Side (Wire 2 (+)): Blue with White Stripe
Front Driver Side (Wire 1 (-)): Blue with Yellow Stripe
Front Passenger Side (Wire 4 (+)): Brown
Front Passenger Side (Wire 3 (-)): Brown with White Stripe
Rear Driver Side (Wire 14 (+)): Light Green
Rear Driver Side (Wire 13 (-)): Black with Yellow Stripe
Rear Passenger Side (Wire 16 (+)): Blue
Rear Passenger Side (Wire 15 (-)): Pink
BOSE Audio System Speaker Wiring Chart:
Back of HU:
Front Driver Side (Wire 2 (+)): White
Front Driver Side (Wire 1 (-)): Black
Front Passenger Side (Wire 4 (+)): Green
Front Passenger Side (Wire 3 (-)): Red
Rear Driver Side (Wire 14 (+)): Brown
Rear Driver Side (Wire 13 (-)): Black with Red Stripe
Rear Passenger Side (Wire 15 (-)): Black with White Stripe
Input of Amp:
Front Driver Side (Wire 33 (+)): White
Front Driver Side (Wire 20 (-)): Black
Front Passenger Side (Wire 35 (+)): Green
Front Passenger Side (Wire 22 (-)): Red
Rear Driver Side (Wire 34 (+)): Brown
Rear Driver Side (Wire 21 (-)): Black with Red Stripe
Rear Passenger Side (Wire 36 (+)): Blue
Rear Passenger Side (Wire 23 (-)): Black with White Stripe
Output of Amp:
Front Driver Side (Wire 30 (+)): Blue with White Stripe
Front Driver Side (Wire 31 (-)): Blue with Yellow Stripe
Front Passenger Side (Wire 28 (+)): Brown
Front Passenger Side (Wire 29 (-)): Brown with White Stripe
Rear Driver Side (Wire 18 (+)): Light Green
Rear Driver Side (Wire 17 (-)): Black with Yellow Stripe
Rear Passenger Side (Wire 41 (+)): Blue
Rear Passenger Side (Wire 42 (-)): Pink
Subwoofer (Wire 24 (+)): White
Subwoofer (Wire 37 (-)): Black
Input of Subwoofer:
Subwoofer (Wire 44 (+)): White
Subwoofer (Wire 43 (-)): Black
Hope this helps. Maybe this should be posted in the FAQ section. I can also provide the power wiring, etc if needed.
Old May 20, 2002 | 01:02 PM
Nathan's Avatar
Re: 2002 Audio Wire Colors
You da man!
Old May 24, 2002 | 01:34 AM
MiniRX7's Avatar
NATHAN, SHAME ON YOU
You have your subs wired out of phase!!!
Reverse the polarity of one of your subs and then it will work properly!!!
I wanna see your powerwire setup, can we meet up some time??
ED
Old May 29, 2002 | 02:13 AM
ThurzNite's Avatar
Originally posted by studman
[B]
where'd u get this info from? it's pretty cool
Jae
Old May 29, 2002 | 06:57 AM
studman's Avatar
Most of it came from the Nissan 2002 Electronic Service Manual (ESM), but I had to verify a few wires as well by disassembling my car to get the color codes.
9aj9
Apr 5, 2020 12:11 AM
popdedop
Sep 11, 2015 11:17 AM
