Suggestions for uprgading my system
Old May 25, 2002 | 09:27 PM
grunge's Avatar
I am thinking of replacing both my amps. I need some suggestions.
I currently have:
Alpine v12 40x4 amp powering my infinity components and coaxials and a rockford power 800a2 running a pair of infinity perfect 10s. The 10s are wired mono and this is causeing my amp to overheat.
Im thinking of replacing my alpine (just because it underpowers my speakers and if im going to redo my trunk i might as well take care of that now) with a xtant 4004 that i can nab for 300$
What should i do about my sub amp? Is there a better (used or new) amp i can use for my surrounds?
I dont want to spend more than 400 for my sub amp.. one option i was throwing around was picking up another 800a2 from ebay for 200$ and using an amp for each sub.... what do you think about that?
thanks
Old May 25, 2002 | 10:20 PM
Gates's Avatar
If that amp is 100x4 at 4 ohms thats not a bad deal at all. I used to have an Orion 800.4 amp that did 100x4 and it sounded awesome. Paid around $300 also. Haven't used an xtant though. For the sub amp you might want to consider a JBL 1200.1 ($250-300). This is what I have in my trunk and you definately will not have a problem with overheating. I can bump for a couple hours and the amp will just get a little warm. Do you not like you alpine or do you just want more power? I ask beccause I have an Alpine 307 (same model?) and I love it. I'm running it 2 channel to my components though, have my coaxs running off the HU. One thing about the JBL, though. It does take a lot of power so you would want to buy a cap if you don't have one already. You'll probably need one if you decide to upgrade both of your amps anyways.
Old May 25, 2002 | 11:23 PM
dipitydoo's Avatar
I would also recommend a class D amp for your subs. There should be plenty to choose from at less than $400. Make sure to match up the impedance of your sub(s) with the amp. The JBL is a great deal considering its raw power output. Also, the Lightning Audio Strike and Storm series are a very good value. I run a Crossfire 1000d on my car, and it works great. I don't believe you would need a cap for your car for a typical everyday driver. You might experience slight dimming on very heavy bass music, but if you play music, a cap isn't a must.
Old May 26, 2002 | 10:24 AM
grunge's Avatar
I already have three caps, so thats not a problem.
Is the JBL clean though?? Im looking for an upgrade from my rockford Im leary or anything that puts out that much power for 300$ PPI and Soundstream and Phoenix all sell 300w amps for 300$ how is jbl able to sell a 1200 for that price?
Old May 26, 2002 | 02:01 PM
dipitydoo's Avatar
The JBL is clean. Many people have bought these amps, with very few problems. There are many reasons various amps of the same power capabilities sell at different prices, brand image being one. They should work fine on the pair of Perfects, if not a bit overpowering.
Old May 26, 2002 | 11:34 PM
Gates's Avatar
The JBL definately gives you clean power. I'm not sure why it is cehaper than anything else with similar power, but it's defiantely clean & reliable. With the brands you mentioned, you are paying a little extra for the name. Also, this amp is meant strictly for subs and is about raw power. I can see why you're hesitant, but this amp has become VERY popular, in part because of its reliablity. I can run it for hours and it won't even get hot. I've been running one for almost a year now with no problems.
Old May 27, 2002 | 12:06 AM
grunge's Avatar
Thanks for the advice but i went a little "bigger" instead
I got an xtant x1001
Number of Channels 1
Watts per Channel 4 Ohm 1 x 500
Watts per Channel 2 Ohm 1 x 1000
Bridged Mono at 4 Ohm n/a
Module Ports 2-Accessory
for my subs.... do you think ill blow em??? the guy at the audio place says i wont.. but i dont know
heres my subs info
Power Handling, Peak: 1400W
Power Handling, RMS: 350W
Sensitivity: 94dB (In Car)
Frequency Response (± 1.5dB): 18Hz - 150 Hz
Frequency Response (±3dB): 18Hz - 150Hz
Impedance: 4 Ohms
Mounting Depth: 6"
i got the xtant 4004 for my surrounds
Specifications
Number of Channels 4
Watts per Channel 4 Ohm 50
Watts per Channel 2 Ohm 100
Bridged Mono at 4 Ohm 2 x 200
What do you think?
Old May 27, 2002 | 12:30 AM
Gates's Avatar
wow that amp looks sweetwhat'd you pay?. I doubt you'll have any problem blowing your subs. Haven't had any personal experience with the Perfects, but I've heard they can take a lot more than they're rated (like most subs), esp. with that 1400W peak. As for the other amp, unless your speakers are 2 ohm, you'll only be giving them 50W each. Not too big an upgrade for 40W. Also, alpine amps are underrated. Your amps probably are too, but like I said I've never used them before. Nonetheless, your system will definately sound clean and hit hard with that setup.
Old May 27, 2002 | 09:11 AM
grunge's Avatar
That amp retails at 900$ but i was able to get it for 550 because i already gave the audiostore 12000 in the last yr for home audio
gigabyte
Jan 6, 2017 06:05 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Pied
Sep 26, 2015 03:29 PM
Socalstillen
Sep 26, 2015 12:01 PM
