trouble with foglights
Old May 28, 2002 | 01:41 PM
venompwr2's Avatar
I just bought fog lights for my '95 maxima (not factory ones) from American Products Co. and they are not working @ all. I have all the connections and grounds made but they will not turn on. Does anyone have any idea what could be wrong? blew a fuse maybe? and how can i fix it w/o buying new lights??
Old May 29, 2002 | 11:37 PM
MIXXMAX's Avatar
Re: trouble with foglights
How, exactly, do you have them hooked up? I have aftermarket fogs on my car, also. Maybe, if you further explain, we can help you.
Old May 30, 2002 | 12:52 PM
venompwr2's Avatar
Re: Re: trouble with foglights
ok, i have the 2 lights mounted on the front bumper and there is a wire that runs from that to a 12v relay i mounted near the battery on the engine wall. there is a white wire running from the relay hooked to the positive end of the battery and a black wire from the relay which is grounded to the engine wall.i ran the switch through the firewall (had to make a hole) and stuck the switch on the dash. there is a red wire from that which i connected to a power source (running lights) and i grounded the switch too. the lights are also grounded. there were 3 grounds i had to make, which seemed like a lot to me. i'm not sure, but did or is something supposed to be hoooked to the negative terminal on the battery?
Heat0212
Oct 24, 2020 12:36 AM
ricky7780
Nov 3, 2015 03:22 PM
Excalibur23
Oct 13, 2015 04:33 PM
zmcneely13
Sep 26, 2015 02:26 PM
Hdnseek
Sep 9, 2015 05:55 AM
