5th gen Bose sub crossover question...
Old Jun 3, 2002 | 07:11 PM
mr_elotoe's Avatar
Diznatin Mizaxima.org Mizember
5th gen Bose sub crossover question...maximadave???
Here's a brain teaser...I'm adding 2 Infinity 10" subs & Kenwood amp to my 2001 Bose system. Has anyone thought of adding or adjusting the built in crossover on the existing sub to make it hit higher frequency midbass. I know the subs I'm adding will handle the lows, but, I'm afraid of having less consistency with the mid bass...
Anyone tried it or have any suggestions?
I am the man that can stump everyone.
Old Jun 3, 2002 | 10:59 PM
ny96max's Avatar
just mess with the frequencies on the amp for the 10's. If your concerned about mid-higher bass try 12's. They are the best all around size to get.
Ant
Old Jun 4, 2002 | 06:50 AM
mr_elotoe's Avatar
Ant
True dat, but, the Bose sub also distorts at higher volumes & lower frequencies. It'd be nice not to have to disconnect it, but, use it instead as a mid bass. I've seen some inline filters that filter lower bass levels out.
I wonder if adding one of b/w the amp & bose sub will get the effect I need. Problem is they are rated for 4-8ohm, but, I believe Bose is 1ohm.....hmmmm.....
Old Jun 4, 2002 | 07:50 AM
mr_elotoe's Avatar
"The only major problem that you will have with trying that is the Bose sub is crossed over in the bose amp itself. If we try to put another crossover behind that then we cause two problems. First the slope of the crossover becomes to steep and you will loose more sound than you will gain and second we could increase the resistive load to the amplifier and damage the factory bose amp. If it were me I would just live with it or remove it. " -Soundgate Tech support Chet
Is this true???
Old Jun 13, 2002 | 07:26 AM
mr_elotoe's Avatar
bump
MAXSE5SPD
Sep 17, 2022 04:00 AM
9aj9
Apr 5, 2020 12:11 AM
Pnjboyzz
Sep 4, 2015 09:04 AM
Lowered_a33
Sep 1, 2015 07:49 PM
