Alarm LED wiring help - where can I tap into?
Old Jun 13, 2002 | 10:27 PM
Nismo's Avatar
I have a varad alarm scanner led and right now I have it on a switch to turn it on (I still have factory alarm) but I would like to know if there was a place where I can tap the wires into so that the light will turn on once I press lock on the key remote. thanks. I was thinking about tapping it to the stock security led but is there a better way?
Old Jun 13, 2002 | 10:36 PM
Nismo's Avatar
ok, after a little searching I read that if I connect the LED to the + battery and connect the negative side to the ground prong of the stock LED light, it would blink along with the Stock LED. Am I correct? or is there something im missing?
Old Jun 13, 2002 | 11:25 PM
Nismo's Avatar
Ok, I just got done doing just that- wiring the ground to the ground side of the factory led and now it blinks along with it when I arm the stock alarm. thanks.................
Old Jul 4, 2002 | 04:37 PM
NikeGal's Avatar
Hey do you have any pics....
Old Dec 27, 2002 | 06:23 PM
Gramdacious's Avatar
I am doing this also, do you remember which wire was the ground for the stock LED, the green/yellow, or the yellow/green?
Old Dec 27, 2002 | 07:10 PM
Nismo's Avatar
I forgot but but I used a battery tester to check polarity.
Old Dec 27, 2002 | 07:20 PM
Nismo's Avatar
5 months late but its the red thing on my rearview http://images.cardomain.com/installs...60_46_full.jpg
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
lrb6805
Sep 24, 2015 05:03 PM
