i will give a cookie to whomever answers this
Old Jun 27, 2002 | 07:38 PM
ZIPPIN's Avatar
Mauja He Mauja
I would like to know if i can use a 2 channel, amp bridge it and run 2 Alpine Type R 12" DVC subs with it in Parallel. The subs are 300 watts RMS 4+4ohm. According to the manual if i run them in Parallel they will have a 2ohm load..
these are the amps i have been looking at
ALPINE MRV-T420
• Max Power (EIAJ) 225Wx2 (4ohm; Stereo) 600Wx1 (Bridged 4ohm
• 12V RMS Continuous Power 4ohm; Stereo (0.08% THD) 75Wx2 2ohm; Stereo (0.3% THD) 120x2 Bridged 4ohm; (0.3% THD) 240x1
•14.4V RMS Continuous Power 4ohm; Stereo (0.08% THD) 110Wx2 2ohm; Stereo (0.3% THD) 170x2 Bridged 4ohm; (0.3% THD) 340x1
OR
Alpne 500m amp
• 900W MAX Power
• 500W x 1 (2ohm 14.4V)
• V12 AccuClass-D™ Design
OR
JBL BP600.1
Output 4 Ohms: 300W x 1
Output 2 Ohms: 600W x 1
Now if you don't think any of the above amps are a good match, or they simply can't push my subs in a safe manner,,,please suggest some amps. My subs are craving for power. I feel bad running them with low power amps...
thanks...i will have the cookies ready
Old Jun 27, 2002 | 07:59 PM
maximadave's Avatar
detailerdaveb@gmail.com
Re: i will give a cookie to whomever answers this
ALPINE MRV-T420
OR
Alpne 500m amp
• 900W MAX Power
OR
JBL BP600.1
I would go with the Alpine 500M or even stronger would be a JL 500/1 for around the same price.
Keep the cookie...I'm on a diet
Old Jun 27, 2002 | 08:02 PM
mb1's Avatar
mb1
Re: Re: i will give a cookie to whomever answers this
Is the JL stable in 1 ohm? I think he should get the JBL bp600.1 so he can run the coils and the subs in parallel and get most power out of it.
Old Jun 27, 2002 | 08:06 PM
ZIPPIN's Avatar
Mauja He Mauja
thanks for the info so far,,but my cookies are good,,,NO FAT,,you can have them even if you are on a diet
Old Jun 27, 2002 | 08:17 PM
maximadave's Avatar
JL puts out a continous output of 500 watts regardless of what load you put it at. No need to run it down to a 1 ohm load and increase your distortion. This amp will be fine for your subs.
Old Jun 27, 2002 | 08:28 PM
mb1's Avatar
mb1
I didn't know that. So at 8ohms and 1ohm, it puts out the same power?
Old Jun 27, 2002 | 08:31 PM
maximadave's Avatar
Yes, but only from 1.5-4 ohms. Car systems run at a 4 ohms not 8 ohms. Most home systems are 8 ohms.
Old Jun 27, 2002 | 08:36 PM
ZIPPIN's Avatar
Mauja He Mauja
i guess i should start baking more..
hey thanks to all of you appreciate it...cookies will follow
Old Jun 27, 2002 | 08:37 PM
mb1's Avatar
mb1
You can still wire subs into an 8ohm load, like one dual 4ohm sub... But I was just proposing an example.
So the JL would be the best bet, but for a budget amp, can't go wrong with JBL.
Old Jun 27, 2002 | 08:46 PM
ZIPPIN's Avatar
Mauja He Mauja
so hook em up like yay
to get a 2ohm load?? and if the diagram is correct, what would be difference in wattage for each amp?
How many watts will
jl 500/1 put out and how many will the jbl 600.1 put out?
thanks
Old Jun 27, 2002 | 08:50 PM
mb1's Avatar
mb1
How many watts will
thanks
You cant get 2ohms with dual 4ohm subs.
Old Jun 27, 2002 | 08:56 PM
ZIPPIN's Avatar
Mauja He Mauja
oops...i just looked at the manual again, and you are right i can't..
the diagram that the manual shows is this one
..which will make it a 4ohm load..isn't this setup in SERIES though? at least thats what the directions suggest
Old Jun 28, 2002 | 08:29 AM
jmax
You can wire each sub at 2 ohms or 8 ohms, then bridge to 4 ohms, 1 ohm, or 16 ohms. So the JL, or any other mono block that is designed to run at 4 or 1 ohm. Or a good two channel amp. The JL may have less power than the JBL, but power without control is just a headache. The JBL's sell for a fraaction of the cost for good reason, they are worth a fraction as much.
Old Jun 28, 2002 | 08:48 AM
srbarnes4ever's Avatar
Looks like a typical series parallel setup. You parallel the 2 voice coils of each individual sub, thus making each sub 2 ohm mono then you wire the 2 subs in series with each other and to the amp...add the 2 plus 2 and you have a 4 ohm mono load with the voltage, thus wattage being shared equally in theory.
doctorpullit
Mar 29, 2016 11:08 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
Marc2theMax
Sep 28, 2015 08:13 AM
lrb6805
Sep 24, 2015 05:03 PM
