FS: 2 IB 10's, MTX 4300x
Old Sep 16, 2008 | 11:14 AM
nismos14's Avatar
§è~® f®ÈÄk
Exodus DPL-10's XBL2 300 rms
$140 shipped
  • Fs: 23 Hz
  • Re: 6.5 Ohms
  • Qms: 4.7
  • Qes: .91
  • Qts: 0.76
  • Mms: 99g
  • Cms: 0.47 mm/N
  • Vas: 73L
  • Sd: 333 cm^2
  • Vd: 1.26L
  • BL: 10.2
  • X-max: 19mm
  • Pmax: 300W
  • SPL: 81.7 db/1W/1M
4300x is $175 shipped Good shape
RMS Power measured at 12.5 Volts DC:
37.5 Watts x 4 into a 4 Ohm load with less than 0.1% Thd+N
75 Watts x 4 into a 2 Ohm load with less than 0.3% Thd+N
150 Watts bridged x 2 into a 4 Ohm load with less than 0.3% Thd+N
Dynamic Power (IHF-202 Std) measured at 14.4 Volts DC
85 Watts x 4 into a 4 Ohm load
140 Watts x 4 into a 2 Ohm load
280 Watts bridged x 2 into a 4 Ohm load
Signal to Noise Ratio:
> or = 110dB A-Weighted
Damping Factor:
>200
Frequency Response:
20Hz-20kHz±0.25dB
Thunder EQ:
Variable Bass Boost (0-18dB) centered at 40Hz
Crossover:
Variable 50Hz to 200Hz, 18dB/Octave, High Pass or Low Pass Configurable
Dimensions:
13" x 9" x 2" (33cm x 22.8cm x 5cm)
14-1/4" x 9" x 2" (36.2cm x 22.8cm x 5cm) Including IsoFeet(TM)
Old Sep 16, 2008 | 11:44 AM
nismos14's Avatar
§è~® f®ÈÄk
$300 shipped package.
Old Sep 18, 2008 | 06:56 PM
nismos14's Avatar
§è~® f®ÈÄk
$170 for the amp, subs sold.
Old Oct 9, 2008 | 12:12 PM
nismos14's Avatar
§è~® f®ÈÄk
150 for the amp
Maxima_Joe
Nov 25, 2015 08:19 AM
tunedup
Feb 7, 2001 08:29 PM
Runutzzzzz
Jan 23, 2001 03:36 PM
