Autocrossing and Road Course Racing Enjoy and discuss the fun through the twisties at your favorite auto-x event. Check out the links to the SCCA website to locate your local club.
1st xcross-help!
Old Sep 17, 2002 | 01:27 PM
A5295's Avatar
1st xcross-help!
I will be attending my first autocross in October...I am already nervous-any tips and hints? I need to know everything that i can-I drive a 4th gen 5 spd SE. THanks in advance for all the help...
Old Sep 17, 2002 | 09:28 PM
voltman's Avatar
Think smooth.
Old Sep 17, 2002 | 11:17 PM
Mrsideways's Avatar
LOOK AHEAD. THATS ALL THAT COUNTS. If you look ahead and overdrive the car you'll be just fine + a few cones. Which is fine. wack all the cones you want on your first event. My first event 4 years ago I hit enought cones to claim Cone Carnage King for the entire year.
Old Sep 18, 2002 | 02:02 AM
Quack 2x's Avatar
Make sure you walk the course a couple of times when you get there, and do whatever you find helpful in remembering it. Some people sketch out the course, others walk the course like they are driving it, looking for the most effective line.
Try over-inflating your tires initially, and putting some white shoe polish on the sidewalls to check for rollover. Check your tire pressures and adjust accordingly.
Make sure everything, and I mean *everything* in your car that is loose is removed or secured down well. A spare tire or jack loose in the trunk and flying around can do a considerable amount of damage.
Like the person before me said, look at where you want to go and drive ahead a couple of cones (i.e., don't drive off the nose of your car).
Last, and probably most important,
When in doubt, ASK!
Hope this helps,
Quack2x
Old Sep 18, 2002 | 03:37 AM
Norm Peterson's Avatar
Re: 1st xcross-help!
If there's a novice walk-through, where an instructor provides commentary as you walk through the course - take it. And for a novice - especially for a first-timer with an admitted case of the jitters, half a dozen walk-throughs wouldn't be too many.
Take advantage of having an instructor ride along with you if it's at all possible.
You'll probably be able to run the entire course in 2nd unless it's unusually fast, so you'll (again, probably) only have to shift just the one time.
Norm
Old Sep 18, 2002 | 10:21 AM
BEJAY1's Avatar
Conecarver
All good tips. Also resist the urge to floor it especially on the turns. The Max has ton's of power and spinning the tires is easy. Go very slow around the turns until you get a feel for how the car is moving around.
Oh, and brake early
Old Sep 19, 2002 | 01:16 AM
KWheelzSB's Avatar
Required Reading. . .
Worth it's weight in gold:
"Secrets of Solo Racing - Expert Techniques For Autocross & Time Trials"
-Author: Henry A. Watts
Paperback: 173 pages
Publisher: Loki Publishing Company
ISBN#: 0962057312
Published: (January 1990)
This is widely regarded as the Solo Racer's Bible & has served novices and experts alike very well for many years. If you buy it, don't worry about "knowing it all" b4 you run your first event. The info's presented in an easy to read approach, but much of it will make more sense after you've had some "seat-time."
(You can probably find it @ www.amazon.com)
Good Luck!
-KWheelzSB-
PS: One hot tip 4u: Remove the windshield wiper fuse before your runs & replace it at the end of the day, b4 you get back on the road.*
*With all the steering gymnastics you'll be doing in the cockpit, it's real easy to tag the wiper stalk. Running the course with your wipers going is not only a mildly embarrassing rookie mistake, but can also be a big distraction as you negotiate your way around at speed, trying to find all the corners in that "sea of cones."
Old Sep 19, 2002 | 09:14 AM
BEJAY1's Avatar
Conecarver
Re: Required Reading. . .
PS: One hot tip 4u: Remove the windsheild wiper fuse before your runs & replace it at the end of the day, b4 you get back on the road.*
*With all the steering gymnastics you'll be doing in the cockpit, it's real easy to tag the wiper stalk. Running the course with your wipers going is not only a mildly embarrassing rookie mistake, but can also be a big distraction as you negotiate your way around at speed, trying to find all the corners in that "sea of cones." [/B]
What about the horn fuse?
Old Sep 19, 2002 | 11:11 AM
KWheelzSB's Avatar
Re: Re: Required Reading. . .
Old Sep 20, 2002 | 12:51 PM
Matt93SE's Avatar
STFU n00b!
yup yup.. At the last auto X I went to, an old guy in a Miata hit his horn every time he came around a hard right. wonder if it was a shorted wire or something. ;-)
James92SE
142
Jan 2, 2024 09:23 AM
user 11122324
42
Jul 18, 2022 03:35 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
wingnut2006
Sep 19, 2015 06:13 AM
jerrod99_se-l
Sep 6, 2015 08:58 PM
